How to: Retrofit Virtual Cockpit
  • Replies 106
  • Views 79.9k
  • Great thread @Tin82   The steering wheel buttons I got supplied with do not have the connectors for the DSG paddles. Part number 3VD 919 719 B    The footprint for the connector an
  • A picture of the rendering
  • I found this thread very helpful for getting my vc up and running, thank you @Tin82 for an excellent write up. Just a couple of notes that may help others.    Amundsen     I
Great thread @Tin82
The footprint for the connector and associated circuitry is on the button pcb just unpopulated
does the bcm module sometimes need changing also?
can anyone add where the gateway module is located? thanks!
I think @Camarao69 might know this.
Hello, Great post,
If you want everything to work correctly for exemple ambiente color in virtual cockpit  in 2016  cars  you need newer BCM and gateway.
This post showld be pinned.
3 hours ago, Camarao69 said:
Hello, Great post,
Thanks! Do you happen to know the part numbers?
You will have to get
5q0937084CQ bcm it can be DD
3Q0907530L Gateway or higher
BCM takes a lot of experience to retrofit.
  • 4 months later...
Hello all!
I gona to retrofit my skoda superb my 2017(10/2017) with mib 2.5(dp3) and acc+lane assist with the AID
I contact the retrofit company by fb its now 80e to 2 key programed
I need to know the Components protection should be disabled before changing the cluster by aid?
Thank you
With me, the coding company removed the component protection after pairing the keys to the new cluster.
When I had my VC fitted, they did component protection, odometer (new cluster), immobiliser and the key pairing using ODIS (remotely using a VAS5054a).
Might be worth checking if the company are using ODIS and will do all the above...?
It can only be done with odis and a valid geko security account.
this is needed for key coding and component protection
Hey everyone
I just swap my cluster by a VC, the hardest part of disassembly was to now how to remove trim and cluster, otherwise the rest was very easy to do,
But sadly after processing by remote coding by VAG retrofit, I had sunroof open need to obtain a better 4g signal to share with my Pc but once the vc cockpit in place COMPONENTS PROTECTION DISABLED
Key programed
Some stuff arranged
My roof doest react at all I had to manually close the roof by disassembly the ceiling light end use Allen key n4...
My vcds doesn't seem to work with CA module I try to self reset by holding press on closure function it had work but just partially it can tilt normally, sliding just a little bit, I also loose comfort function but I guess it's due to missing calibration
Anyone can help me? A way to follow
Thanks all
Hi everybody, anyone know how to change car representation on virtual cockpit I have a combi and the representative view on VC is a berline
On 30/09/2021 at 10:22, Gagaetan10 said:
Hey everyone
Key programed
Some stuff arranged
Thanks all
Hi !
Did you find a fix for the sunroof?
I’m facing the same problem.
The sunroof has stopped responding and keys have also lost its convenience functions.
Thanks in Advance.
Please do reply.
Sadly not yet, my vcds clone aren't compatible with the CA sunroof, and last think I could do is to try with Odis otherwise I'll go to my car dealer
Mine is working now.
Put your car in ignition. Try pressing the sunroof button down (Not front or back) for 10 seconds. Like what you when the sunroof is on tilt and you have to close it.
It’ll recalibrate and start working as normal. Atleast mine did when I followed the above steps.
I had already try to do this but it's tilt and no comfort function or total opening, I have the same with sunshade
  • 5 weeks later...
Hello everyone, so I m come back, I'havent yet successfully set my sunroof/sunblind even with Odis when I start a guided function to make a parametrization it end by a fail not normed...
I don't know what to do
Other thing on my 5f infotainment I couldn't obtain the personalization menu for the virtual cockpit
And a last thing the picture show on VC isn't a Combi version it instead a Berline look
Thanks everybody for your help
Have you tried just running the sun roof and blind back and forth a few times.  Go to the test plan tab and it will already be there.
changing the car displayed should match your original coding so should be the same, if it doesn’t it’s a coding issue.
What software and method did you use for the 5F menu?
Hey, yes I tried many time to run the sun and blind back and forth, maintain the back buton 20second, the forward same, it goes back and forth a bit only 15cm and no more
Maybe should I totally open it manually to reparametrize all? 🤔
About 5f
I use the méthode in first post who said I need to adapt some line on vcds adaptation menu but somes of them could be activate with
Amazing work! Great job.
I would really be tempted. But a bit too tricky for me. I would fear something goes wrong or I couldn't code something correctly afterwards.
About 5f
I had same issue it would keep failing on vcds adaptations. Instead use odis-e for the 5F adaptations and it works perfectly.
So you mean on the test plan I could move it manually controlled by odis?
Because I tried many times to set with the closure button, for both
And about odis-e means to have a geko account
