Everything posted by zacko_O
Not today, but finally found the way how to convert seat unit from 5Q0959760B/C/D/E/F to 3Q0 with lumbar massage About an hour of soldering, then firmware, and we get a unit with a massage
Drivers mode
Read it until the end - the driving mode itself is also described there. It’s 2026 - translators have existed for a long time already. btw, If you don’t have ODIS, VCP, etc., there’s no point in trying to figure it out.
Drivers mode
This can be changed only by modifing gateway dataset.
P0684 - Glow Plug Control Module
Then you can replace module E.g. Bosch 0281003085 costs much cheaper then original
Easier to measure from controller side. There pins G1-4 on module, measure each one to ground. If infinite or more then ~10 Ohm - replace glow plug
Eject control module, check resistance of each glow plug, should be few ohms. If yes replace control module.
MY17 Superb Retrofitted with Direct TPMS
So yours might actually be original. From my experience, fake antennas started flooding AliExpress about 2.5 years ago, but it seems there are still some sellers offering originals. What was wrong with my AliExpress kit: Periodic U012700 error in the gateway, indicating no communication with antenna no automatic wheel position detection front left sensor had poor reception one sensor always showed 2.2 Not sure what will happen if I change sensors
I’ll share my personal experience. Fake on top, original on the bottom. The QR code on the Chinese ones looks identical (if you compare it with the photos a few posts above). The font of the part number is different (not noticeable in this photo). The Cyrillic text is poorly done. "ЗроблеНо в НiмеЧЧИНi" - fake. "Зроблено в Німеччині" - original There is no Huff / BHSens logo. - fixed in new fake antennas You can't upload dataset If the antenna is already installed, you will see this menu in the Tire Type settings. Of course, they’re not standing still and keep improving the fake antennas.
this one looks like a fake topics to read: https://www.drive2.ru/l/673718879045834225/ https://www.drive2.ru/l/717594065918495629/ https://www.drive2.ru/l/648258312915128932/
Yes, new sensors will be automatically detected after half kilometer. But if it is genuine VAG antenna. Btw it’s possible to manually put sensors ids via diagnostics tools For fake antenna you can’t upload dataset with tire pressure settings.
98% TPMS antennas from Ali are fake
Clock spring replacement
@SuperbDan 👆
Coding of Steering Wheel controls
You need Lin module the buttons should work like this: Left button - Main Menu Right button- View More details: https://www.briskoda.net/forums/topic/522203-new-generation-steering-wheel-swap/
well, we can only guess, because we don't know what equipemnt you have. E.g. in my Superb coding was 6410 Open coding and check whats is extra is on or off
There 2 versions of 5Q0.953.569A clockspring for VW w/o third stalk fo ACC and for Skoda with third stalk support. Try to restore coding from previous clockspring, if it won't atccept coding, probably you bought clockspring from VW Another option is restore your old one
I did it with an adapter, but in mqb
Voice - 0x19
Maybe you need press button to show values? it will show value in DEC
Gateway - Measured Values
Canton Subwoofer Amplifier Issue
Read DTCs in 5F Most probably you have B130C 13 or B130D 13
VCDS options on Superb III.FL
[Superb 3V] MY2020 Heated steering wheel retrofit - almost complete
I have to ask, did you restart the climate module?
yes, only changed Heated_steering_wheel_version what Lin module do you use? I know that one of them sends extra command when you press button to enable/disable heating
Check what do you have in 08 Climate Control Module cdoing - Heated_steering_wheel_automatic_mode
I didn't get you, you wrote: "From factory the steering wheel was heated." My question was about module for Steering Wheel buttons? needed for View/Menu etc. Yesterday I helped to guy with Superb 2020, he had "old" style heated SW and installed new 2025 heated SW. He coded 3v0907044fa and all good - [LO]_Heated_steering_wheel_version: [VO]_LRH_Gen_2_mod
