zacko_O
Everything posted by zacko_O
  1. I used a homemade hook made of wire. You need to pull the latch; if you shine a flashlight, you'll see it.
  2. Rule number 1: use fresh SD card:)
  3. It has better specifications, performs much better in lane keeping, recognizes the roadside and linear objects, supports capacity steering wheel(you need to keep your hands on the wheel and there will be no notification during ACC) The replacement is simple, but not everyone can activate the SWaP codes, but possible remotely
  4. 3Q0 -> 2Q0 camera retrofit with all SWaPs and TravelAssist with KLR now work As a bonus, I installed a frameless mirror
  5. It’s hard to answer without knowing what you currently have. Most likely, you need to look for the 5Q1 module, which comes with the switches. People do sell used ones separately, but there’s a risk they might not work. Find a set with the same functionality for the switches and heating support. Ideally, compare the PR codes.
  6. Yes, that’s why there a lot of issues after retrofitting 569B. Only after disassembly or connecting to car you can check.
  7. I was curious and assembled all this on Arduino. This adapter works with the CAN bus, intercepting commands from the GW and sending the necessary message based on them without canceling the original message. There’s a nuance for VC owners: the View function can only be assigned to the TravelAssist button. If you assign it to the lower right or left arrow, it will work in 1 out of 20 cases, as these buttons in the VC open the central menu. As a result, the VC cannot simultaneously change the view and open the central menu. It’s possible to assign the View function to other buttons, but it would be wired. For example, assigning it to the voice assistant button would trigger the voice assistant and change the VC view simultaneously, and so on. To summarize, if possible, it’s better to choose a module based on LIN. LIN modules work inline with the bus and simply replace messages. But Arduino modules much cheaper.
  8. Ok. I know that there is an issue with the steering rack clunking on MQB, which can be resolved by lubrication and tightening of the steering rack
  9. Why did you replace steering rack?
  10. Ok, here’s the result of my research: I ended up installing the 5Q1. 5Q0953569B — This variant is ambiguous. If the module is from VW, it does not include components for the third ACC stalk. The same applies to 5Q0953569A (this also concerns both A and B). It might be possible to solder the necessary components, but to be sure, it's better to get it assembled with the stalk. 5Q0953569C — Starting from 01/12/2019, the 5Q0953569B modules were replaced with 5Q0953569C, which were installed exclusively on Skoda. Apparently, this confusion became a problem for everyone, so they created a dedicated module for Skoda with support for the third ACC stalk. Transition to the new 5Q1 module — These began to be installed on facelift models and are no longer standalone "16 modules" but rather a "submodule" of the BCM. In the catalog, the stalk and the steering column module are listed together under a single part number. After spending some time on the diagrams, the following differences were identified: The 5Q1 module no longer receives the CAN Comfort connection. An additional LIN bus is added to the BCM module at T73c/54. Airbag contacts are now combined into the same connector as the others. The transmission lock switch is now routed to BCM T73a/24. This variant is possible only with newer BCMs. Visually, the necessary pins appear starting with version 5Q0937084CQ (installed from 01/06/2017). Whether it supports all functionality 100% — I cannot confirm. Will add more details later
  11. Do you have Odis and can send scan?
  12. Did you restore adaptations properly?
  13. I saw in Octavia topic you suggested to use 5q0953569C clock spring. Do all 569C clock springs support ACC? Or it is same problem as 569B, one part number, but it doesn't obvious is it support ACC or not
  14. No, Travel Assist requires 2q0 camera which began to be installed from ~2020. Unless you retrofitted it before.
  15. This is Travel Assist button, that you don’t have. Some modules have feature to reassign this button.
  16. Check the second link, I guess this is exactly what you bought.
  17. https://github.com/GabrielMastny/Skoda_2021MUFUSteeringWheel_Converter/tree/main https://wirer.sk/o3_volant22-modul/
  18. You need conversion module. You can make it from Arduino or buy (e.g. https://www.cars-equipment.com/en/shop/radio-adapter-can-bus-decoder-22/canbus-adapter-reduction-for-steering-wheel-2/)
  19. Coding and custom dataset. Fixed what? Inside tailgate just 2 new wires for new buttons
  20. For color change according drive modes, BCM also might need to update Check adaptations in BCM, e.g. Ambiente_Farbwahl_FPA_waehlbare_Kopplung
  21. Yes, try to change flow directions and probably you will hear noise. I read few topics and for plastic gears it’s better to use silicone. So I used silicone spray.
  22. yes, it will work. I have 2015 Skoda Superb, originally MHI2 was installed
