Everything posted by zacko_O
Put grease on white mechanism. You can reach it through left or center hole, in case you have a speaker you can remove it(left speaker mounted by 2 screws, center speaker by 4 screws). Once you reach white mechanism, hold tube and spray silicon into the tube, then change flow direction and spray again. Do it few times. I uploaded video how it works
The climate control mechanism started making noise. I removed the top cover of the speaker, made a tool from a cheap endoscope and a Cilict Bang tube, lubricated the white mechanisms with silicone grease. Now the noise is gone.
New FL Skoda Superb 2020 tail lights - retrofit?
Swapped Here I described how https://www.drive2.ru/l/681792318050668410/ Even I developed app to sync most of the adaptations
5Q0937084EC
Finally, I've finished today. Now I can add all details Wires schema. All wires 0.5mm except mentioned, for RH rear fog light will be on right inner side T4e/1 - T6bh/1(double check it). Preset, all adaptations for FL BCM, but you can use it for preFL BCM. preset And video
Superb 2.0 tdi frequent regens.
Did you check pressure sensors with pressure gauge?
How-to Guide to Upgrade MIB2 to MIB2.5
Check price for 3V0919606E on Aliexpress - this is from Chinese version of Superb, I had 3V0919606D and now I have 3V0919606E - all same.
It prevents closure if key is too close and also puts car on guard. So you don't need close car from remote or touch kessy handle after lid closed. 5Q0959107M/Q/T rear lid module + button 3G0959832AWHS
For 30 colors selection you should have appropriate BCM. If you have it, you can find how to do that in forum search
mib2-toolbox allows you to update skin images in MIB, so you can put any image wherever you want
VCDS options on Superb III
Does anyone know how to increase ambient light brightness? They brighter when door opened, probably it’s possible to make them brighter all time
Since I've done retrofit of VC, steering wheel and Columbus display. I changed ambient light, climate menus and main menu icons to new ones from MIB3
Yeah, I started from BCM, FL tail lights will be next:) PM me if you need help with adaptations
I changed only display(3V09119606E/D), I had MIB2 High and converted it to MIB2.5 High, you can find more details here. Virtual cockpit 3VD920790, ordered from Aliexpress
No errors in Gateway(Lear) and no errors in any other control modules. I had error related Alternator but I fixed it. I use dataset from mibsolution(it's only one for Superb)
Active Info Display = Virtual Cockpit 🙂
After 9 months finally got this view for my Superb 2015 1. Steering wheel 2. MIB 2 -> 2.5 convertion 3. Gateway 5Q0 -> 3Q0907530AC 4. And now I've installed AID
Is it works? What BCM do you have?
DCC Slider adjustment option mod
Looks like you already found solution Anyway I can add details here In addition, need to add all these values to Individual mode to show slider. I've updated 5Q0907376A to 5Q0907376C just now
By default, if you select Sport mode and after restart, mode will be in Sport mode, but DSG will return to "D" mode You can edit your FPA dataset to prevent this.
I've installed Soundaktor/SAK only for Sport and Individual mode and remember DSG mode after restart
Battery drain - Columbus update?
My opinion - no. What else have you done from April? Maybe trunk bulbs? It’s very popular problem
New generation steering wheel swap
What adapter did you install?
