ile7
Everything posted by ile7
  1. @fr1nklyn 1. True, sensors will gone no matter what. 2. After 2020 new sensors used 3. Change both sensors ofc 4. https://getriebeshop24.de/products/hydraulikdrucksensor-satz-kupplungspositionssensor-inkl-dichtun Don't use crap Asian sensors!!! 5. Yes, after sensor swap Basic settings have to be done!
  2. No, it is common problem with dq381 gearbox.. Google it
  3. K2 sensor broken on mechatronic unit, replaced the sensor instead changing whole unit
  4. https://mib-helper.com/index.php?train=MST2_EU_SK_ZR_P0359T#details 0480 latest
  5. Good luck with new stuff, any conclusion about busted engine? How ride feels now on eibach? ( pro or sportline springs? )
  6. Recently I repaired my mcu board, paid 850€, both sensors replaced, oil and filter.
  7. Yes K2 sensor broken in this case
  8. Could be done cheaper, refurbish your mcu and put new oil with filter.
  9. Did your oil vacuum pump made ticking sound on cold start? Main skoda dealer told me it is normal and nothing to worry about.. Check video pls https://youtu.be/g08CYMs1kMU?si=oyb3CpyZB_8hBTkt
  10. Unbelievable.... Pls share further info about this
  11. Engine busted? Anything can be done to prevent it?
  12. @MartiniBpart number: 8J0 947 409 B, white led? Does it fit to combi boot lid tailgate?
  13. Anyone know the part number of facelift model luggage lights? PreFL got yellow leds but FL model is white leds. Don't want aliexpress version too bright for me
  14. Should be solved after 2020, but who knows.. recently I changed both sensors on mechatronic 11/2018 production date
  15. Did you change 527 relay?
  16. Same here, 2.0 TDI doing morning drive to work cca 13km after stop engine still at 1000 revs, speak to friend with same engine but longer ownership he told it is normal for Euro 6 engines ...
  17. Do you think Fuchs FFL2 is right oil for dq381? It is different part number compared to OEM oil, but the service guy only do gearboxes and said it is the only brand he use since Fuchs is OEM oil in all wetclutch DSG's?
  18. Today paid 850€ for both sensors change, filter and oil ( Fuchs FFL 2 )
  19. Im sure you will need unit or repair yours soon or later. It is well known problem and we are affected...
  20. Update! Error is back! Time to repair mechatronic unit, one day went without problems today after 10 min of driving error came back, luckly I came home safe with manual changing..
  21. Hit it few times that day until battery changed during the trip because was dead. Might be faulty mechatronic since it's well known problem, easly.
  22. Still driving since then, without errors. Tomorrow will do 500km trip and report. Done around 5000km since August when error randomly appeared.
