Everything posted by scotthugh3s
Error rear parking distance control
Then I suggest you don't have it. How far are you from @East_Yorkshire_Retrofits ? Kieran can diagnose and apply any missing software updates to your car in the exact same way a dealer can, but at a fraction of the cost...
Do you have Obdeleven?
Goodbye to Skoda (and getting rid of some stuff too)
Have you considered the Scala?
Might sound daft mate but have you checked your battery? I experienced a problem with random faults flagging up recently when I was running a (close to) flat battery... I actually didn't consider a wiring issue, it could easily be that, or a faulty module perhaps? Via my own experience with modern cars, I'm always keen to consider an alternative fix to the one a dealer would recommend For instance just recently I had an airbag light I couldn't get rid of (which was initially triggered by the flat battery I mentioned above) Skoda's solution is to replace the module which would cost around £1,500. Turns out there's an update you can apply via ODIS which fixes it though, which thankfully I discovered with a generous amount of help from good internet folk. Skoda keeping quiet on the update cos obviously they make more by switching out the module, totally unneccessarily Do you know if your vehicle's software is up to date? I don't just mean the infotainment, but each individual module?
See I always push the start button with no clutch, then leave for a few seconds before dipping the clutch to actually start the car. Just as prior to start buttons I'd turn the key to ignition for a couple of seconds before actually turning to crank it. I was always led to believe that you need to let each of the sensor lights that illuminate at the point of ignition to dim before cranking, as the fact they illuminate is to do with the electrical current reaching them, then they dim to let you know that everything's fine and you're good to go. If you're cranking before allowing this process to occur, which is essentially the electrical system performing its own start up check, then you risk confusing it which could lead to problems such as the one you were having. I genuinely believed this was common knowledge, I wonder how many others who start a car like yourself have ended up enduring the same "issue" as you have. Honestly seems like a self inflicted or non issue to me. Failing an actual faulty sensor, the other things that may possibly throw up faults are cold weather or dirt, where a frozen or dirty component isn't operating as it should in frozen temperatures / dirty conditions, which should correct itself once it's cleaned / reaches operating temp. IMHO, if you began and continued to use the (correct) method of cranking I've outlined above, you'll likely never experience the issue you were having again. Outside of cold weather / dirt or an actual faulty sensor anyway. I honestly doubt whether there's any such "TPI" exists, it could be the garage owner have just held on to your car for a couple of hours and had a little giggle to themselves...
G-meter issue (obd 11)
I'm trying to explain how to make it visible. The coding will have added it as an option for your dash display, but then you need to access the settings on your dash via the button on the steering wheel (right hand side) Go to settings and find the g-meter option you've now made available, then click to activate it as in make it selectable (put a green tick by it) Afterwards you should be able to find it via the scroll option on what to display. I'm not 100% certain this will work as I haven't added them g-meter myself, but I did add the compass and this is how I got that to show up on my dash after coding
You need to make it available for selection on your dash display. Press the button on the right of your steering wheel, scroll for settings and enable it from there.
- Constant Software Update Notification
Dealership's will always deny knowledge, that way they can squeeze more money out of you
OBD11 Coding list for Octavia MK4 / IV
I have pre facelift Octavia IV. I managed to activate standard CC in the end, I didn't realise to make changes on that particular module you have to enter a security code, DOH!
OBD2 Tool
Be sure to do a back up before you try anything. Follow instructions carefully. If unsure, ask. And don't use one click apps, well I don't anyway, as they leave no traceable path of anything they change. These things don't perform miracles, but they do unlock features in your car that, although should be unlocked as standard, aren't.
- OBD2 Tool
Radio Question
Yes it will, if you just want the radio off then mute it
^^^ can tell I'm new to OBD11, turns out I haven't been using the security access code, didn't know I had to lol
Radio Question
There's a 'standby' logo at the bottom left of where the screen is located. Press and hold that for a second or two.
Caved in and bought an OBDEleven device + Pro plan in their recent sale... Have attempted to activate standard cruise control numerous times via the above method but it doesn't work. I've read elsewhere that you can only do it via One Click Apps, could it be that OBD11 have now blocked you from manually coding it? Real shame like as I've implemented a few other bits and bobs, some from above and others I found elsewhere. It's a really nifty bit of kit, can't tell you how it feels to no longer have to manually switch off lane assist every time I get in the car 😄 Not really wanting to use One Click Apps after reading in some places that they can cause issues, but if it's now the only way to enable standard CC..... 🫤
OBD2 Tool
My advice would be to wait until OBD11 put on a promotion, that's what I did, bought the latest Gen 3 scanner and got a year's pro license for around £95 Has proved very useful since I bought it, if I was to never use it again I'd be happy enough with what I paid having made the minor changes it allowed me to, which make my overall experience of the Octavia IV a more pleasurable one.
- OBD2 Tool
Smartlink notifications
Apple car play works via smart link does it not? 🤔
Airbag error (B200000)
I've pm'd you mate, thanks 🙂
Actually, what time could you do on Saturday, if any..?
Can't do the back end of the week unfortunately as I have prior commitments, but I appreciate your offer and may well be in touch soon to act upon it 👍🏻
Thanks, problem is I'm a good 7 hour drive from East Yorkshire 😅😪 Although I have a couple of days off work early next week, is that too soon for you?
Fault code P056200 low voltage
What's the app you're using in those screenshots please?
