Everything posted by Benja77
Dash cam port C on rear view mirror
I don't think adding a fuse, especially if You have the slot free and available con ruin the electrical system
USB-C port on the mirror works only with car turned on; if You wanna constant power on a dashcam best way is using it with the fuse box or with an external power bank
How to: Travel Assist and Heated Steering Wheel Retrofit
Does the aircon coding allow me to turn on the heated steering will from infotainment display too, and eventually turning it on automatically? Do You also have the coding for the heated seats?
MY17 Superb Retrofitted with Direct TPMS
Thank You!
Yes I have the same, now have to codify it; any suggestion?
Just one question: does the control unit has to be put horizontal or vertical works the same? I ask You as it seems impossible to fit horizontal, without risking, in case of rain, that the wires near the plug can get water! Can You help me?
- Side steps / running boards fitted
- From Amundsen to Columbus: mission almost accomplished!
Kopacek Running Boards V2 on Karoq: anyone fitted?
As above: did anybody fit them? I’m having trouble while fitting the lower supports: can someone help me, better if taking pics from below! I do have a 22 FL
Hi there! As many of You know, among the several retrofits I’m doing on my Karoq, there’s the screen update, from Amundsen (8 inches) to Columbus (9,2). While the rectangular connector fits perfectly (audio works and buttons turn on), the screen remains black due (according to mechanic) to the different Fakra connectors, blue on Amundsen and Black on Columbus) as they have a small tooth in a different position (top on one, bottom on the other). According to You/Your experience, replacing the cable can solve the problem?
Do Superbs have heated seats?
Can You show me/us how the seat look like from the inside, meaning with the door open, front 3/4? Are they power seats too for regulations?
Parts For Sale: Travall Dog Guard for Karoq
Still available? fits on a 2022 FL?
Mk3 Octavia 19” Extreme wheels x4
How much just for the wheels shipped to Italy? Do they fit on Karoq?
- Blind spot assist retrofit
Heated Front Seats & Steering wheel: what's the coding?
About the coding for the seats, is there any particular procedure? About instead the steering wheel, installation and coding, instructions were provided with harness
Of course if the upholterer, installed the driver side on the passenger side and viceversa, the connections must be inverted, apart the brown/white, isnt' it?
Thanks
2 Brown/White: where? 2 Brown (Mass): it doesn't matter where?
An update, This morning I went to the upholsterer in order to make pass the resistences for the heated seats: while connections between back and seat these two and main harness Were pretty hease as the connectores matched perfectly, once the job will be done, I'll have to connect the main harness to the ac control unit which I propoerly bought, replacing mine with another one with the heated seats buttons. The main harness thas the following wires 2 brown with eyelet which I suppose are the mass (1 for each seat) 1 red and white for one seat + 1 red and yellow for the the other seat, each with big terminals 1 blue and white for one seat + 1 dark blue (almost black), each with small terminals 2 brown and white which join at the end in a unique small terminal Where do I attach this wires? Attached You can see the photos
reversing camera
I have the opposite problem, after retro fitting the area view 360° and Park Assist: I wanna see it but I cannot: can anybody help me?
boot torch
That frame that surrounds both of the torch and the 12v is NOT available as spare part or at least is why my dealer told me!
Mine is 22
About TA problems
