Cairus
Everything posted by Cairus
  1. If the 12V battery has a short circuit, it will be empty in a short time... How do you test the battery? With a load test? Everything else is worthless.
  2. Yes, technically possible. New steering wheel with buttons. New connection cable for coil spring airbag with/for MFL. Maybe Pull LIN cable. Code everything.
  3. Reinforcement plate(s) - subframe to body, step 1 20 Nm Replace screw(s). to body, step 2 90° Front axle stabilizer mount to subframe Step 1 20 Nm Use new bolt(s). Step 2 180°
  4. There are users who have installed it in the Yeti Facelift or Octavia 2 Facelift
  5. Look history (4).txt history (3).txt
  6. A complete scan with full SFD 2 protection is possible with gen 2, I have done it myself with a Skoda Karoq 2025
  7. Thank you, I'm familiar with the subject... you should therefore know that even with the SFD 2 contract with VW, which is currently being negotiated, it would never be possible to process SFD 2 with gen 2. The hardware basis for SFD 2 was implemented with gen 3.
  8. the saying was meant rather sarcastically
  9. For the first problem, update the radio system. For the PDC problem, it sounds like water is getting in.
  10. I know of cases where nothing worked despite preparation.
  11. SFD 2 or SFD 1?
  12. If you live in Europe, be sure to get a factory-fitted tow bar for a new vehicle. This will save you any SFD 2 discussion when retrofitting.
  13. Which year is the Car?
  14. If we'd like to add the coding for the steering wheel heating: Control unit 08---> Coding ---> Heated_steering_wheel_and_Heated_steering_wheel_automatic_mode Set To Active
  15. Make Full Backup with OBD11 and Post txt File here
  16. If you can use the Internet and Google, you will find everything you need
  17. Don't get me wrong, but something like this simply has to be in the manual. Regarding coding, the instructions always include byte and bit information. Using these information is OBD11-bound.
  18. you need an edited meta file and the ToolBox
  19. On the steering column control unit, it's connector T14e/1, which is terminal 30 for the Z36, with a cross-section of 0.5 mm². Then, T14e/2, which is terminal 31 for the Z36, with a cross-section of 1.0 mm².
