Damian@DPM
Sponsor
Everything posted by Damian@DPM
  1. Thanks. Yes that is the correct kit - https://www.dpmperformance.co.uk/car-parts/skoda/octavia/st-20mm-springs-shocks-suspension-kitoctavia-1z-20042013-20tfsi-vrs-20tdi-vrs Damian @ DPM Performance
  2. Morning, Look correct but what's your registration number and I'll confirm? Damian @ DPM Performance
  3. The B4s are basically a gas version of the standard shocks, the B6 are a monotube upgrade but as mentioned fairly firm. If I was keeping the standard springs, personally I'd go for the Koni Special-Active. Damian @ DPM Performance
  4. Drop us a PM with your reg and we should be able to answer your questions. Damian @ DPM Performance
  5. If budget allows yes. The ST kit is the next step up from the AP in terms of the quality of the parts used and also the build. Damian @ DPM Performance
  6. ST by KW would be my recommendation - https://www.dpmperformance.co.uk/car-parts/skoda/fabia/st-20mm-springs-shocks-suspension-kitfabia-6y-19992007-19tdi-vrs Damian @ DPM Performance
  7. I'd go for the ST kit every time. Damian @ DPM Performance
  8. Drop us a PM with your registration number if you're still looking and we can check what is available for your model. Damian @ DPM Performance
  9. Have you checked what clearance you have? Hold something flat against the arch and measure from the tyre sidewall to that. Damian @ DPM Performance
  10. What dampers are fitted with the H&R springs? Damian @ DPM Performance
  11. Drop us a PM with your registration number and I'm sure we'll be able to help. Damian @ DPM Performance
  12. You'll be fine with a 12mm hubcentric spacer - https://www.dpmperformance.co.uk/car-parts/skoda/octavia/hr-trak-12mm-hubcentric-wheel-spacers-boltsoctavia-5e-20132019 Damian @ DPM Performance
  13. The front hub lip won't be as deep as the rear, we've found from experience that 10mm works on the front but 12mm+ is needed for the rear. Damian @ DPM Performance
  14. From what you've said springs and shocks are going to be the better option for you over coilovers. Drop us a PM if we can be any help and we can get some prices and info on kits together for you. Damian @ DPM Performance
  15. As above really. If we can be of any help just PM over your registration and front and rear axle weights. Damian @ DPM Performance
  16. Drop us a PM with your reg and we can get a price for you. Damian @ DPM Performance
  17. I'd recommend changing both the fronts and rears. Let us know if you'd like a price on the Koni's. Damian @ DPM Performance
  18. Best thing to do is to hold something flat against the arch and then measure from the tyre sidewall to that. This will give you the exact measurement to get the wheels flush, you can then take a few mm off for clearance. Damian @ DPM Performance
  19. Morning, Are you wanting the wheels flush with the arches or a little in? Damian @ DPM Performance
  20. You'd get maybe 10-15mm lower. Damian @ DPM Performance
  21. Excellent quality kit if you're happy with a set drop - https://www.dpmperformance.co.uk/car-parts/skoda/octavia/bilstein-30mm-b12-pro-lowering-springs-shocks-suspension-kitoctavia-1z-20042013-16tdi-19tdi-20tfsi-20tdi-inc-vrs Damian @ DPM Performance
  22. The ST kit by KW is a great option although a little over what you wanted to spend but worth saving for - https://www.dpmperformance.co.uk/car-parts/skoda/octavia/st-x-by-kw-coilover-suspension-kitoctavia-1z-20042013-14tsi-16tdi-18tsi-19tdi-20tfsi-20tdi-inc-vrs Damian @ DPM Performance
  23. Top mounts and bearings are always worth changing whilst the suspension is off. Damian @ DPM Performance
  24. The Whiteline bars are in stock at the moment. Damian @ DPM Performance
  25. With that mileage you'll really need to go for a full springs and shocks kit and the Koni kit is a good place to start. 40mm should be fine and the standard drop links should work without any problems. Damian @ DPM Performance
