Everything posted by skoda1982
Huge Red Car Icon, why?
You can set the sensitivity in settings set it to LATE so it doesn't recognise cars at junctions if you are turning left
Brake disc rust/scoring
It's the vag group supplying them not skoda
Permanently disable Kessy on Scala SE L
Not really understood kessy didn’t see the point so much messing. so stayed with press the open button to open the doors you select in settings get in press start button. Press stop button get out shut the door press once locked with deadlock press twice locked without
Potential Kamiq 1.5 SE L Executive
What I put as mobility offers are.manual
The Kamiq monti carlo 1.0l 110ps is £0 advanced and the kamiq SE Drive 1.5 is £95 advance. Both manual. 1.5 SEL-E is £595 manual advanced
- Kamiq 2023 facelift.
Satnav update...Where is.....
Maps are done twice a year and are not backdated the next is about June. Check your version of nav update and the one now
You cannot load from Skoda portal on a memory stick it has to be done on a Skoda memory card. The kamiq system won’t read it
Why would thieves want to steal a Skoda scala. Stop worrying about wether it’s going to get pinched and enjoy the car
Samsung Galaxy S22 series failes to connect to Android Auto
It’s not compatible check Skoda compatibility website
- Kamiq Service Intervals
You cannot update from the portal for the kamiq it’s done by Skoda connect that does it automatically when one is due if you don’t have Skoda connect you won’t get them
You cannot permanently disabled kessy. in car settings you can alter what doors open. And as a safety measure the key turns off after a few minites when not touched/moved so it cannot be read. Get the MyŠKODA app so you can track your car it acts like a tracker.
The Fabia 4 is not a facelift its all new. They have to keep it looking something like a Fabia otherwise it would have a different name
They have put it on hold as to reduce the backlog of current version may be end of year or early next. If you have put an order for current version this what you will get you have to do a new order for facelift when it comes out
- 1.5 TSI idle and ACT
Display question
Turn the brightness down in settings you can even do it for your vc
The 1.5 tsi does not have COD. Is the engine vibrating all the time or just when ACT is activated (eco) on dash. ACT only activates when driving so they cannot say its how it is. Go to another Dealer or reject the car. I have the 1.5 tsi and I cannot tell it running even when it changes to eco. I only use Shell fuel
Front seat backs, range of movement query
Are they electric or manual
Looks like the weather direction is affecting that. I go to a empty car park drive about 5/10 mph and apply hand brake not clicked on but with button pressed in and pull up and down to clean. You could try replacing under warranty but you might get the same
2yr review..!
And he will wish he didn’t drop the Skoda brand🤣
Fabia 2008 1.9 tdi sport rear back box
Didn’t know that they were stainless from the factory. There’s a rusted plate that goes around it
Fitting Variable Boot Floor to Scala
The Kamiq and scala have both the exact same interiors it’s just the body that differs
Scala SE 1.5 engine. Manual box.
Not heard that if it was you can only have the 1.0l. They stopped the Diesel
Replacement Car Battery Skoda Scala 2020 model year 1.5tsi (act) DSG
If you’re car is under warranty claim for a new battery. Some batteries in 2019/20 were faulty and changed
