pastiche
Members-
Posts
425 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by pastiche
Took the plunge and bought the OBD11 Inteface plus downloaded Torque app. It is supposed to give all results in what is required. Which in my case is the engine warning light coming up now and again. Having tried several times without success. All I am getting is Bank 1 and Bank 2 ok , then still with no numbers but following..Test in compleat Test failed.MID 31 TID CO Boost pressuurebank 1 Missfire cylinder 16 data. To me this is all gobble duke talk. Any one got idea what it is saying and why I cannot get the code for each item requred?. Thanks.
My EMC light did not go off after starting plus as I have dsg it would not engage whether forwards or reverse , Stopped engine ,waited and restarted. This time the light did go off and gear select worked as well. Are the two related and advise please what to do. It had service in October. Thanks.
Well this week has been a mystery with my Octy. Had service three weeks ago so thought everthing was ok until when going to start up it did not start which was a first. Wated for thr glopwlugs to warm up and it went ok. The warning light went out after a while but came back later.So went down to my Skoda dealer and they put on the "tester" and it seemed that no confirmed items came up . They said it could be anything from glow plug , loose wire and so on . Whilst the motor is working fine just keep aware of it otherwise it might be a costly investigation or next to nothing. It has done 117 500 miles , regular servicing since new and pulling my caravan a good mpg 27/34.
Now getting concerned as to why the fan is running when engine off for some time even on few mile run , is something going wrong?
Octavia Battery Drain Problem
pastiche replied to johns taxi's topic in Skoda Octavia Mk II (2004 - 2013)
Two years and 51 weeks my Varta battery packed up without .warning. As mentioned only one week left for warrantly. As you have to pay to return it Idid not do it.. So bought another with 5 year warranty £105.. Strange that original one lasted 9 years. -
Thank you
For some years now after using the car that the fans or whatever it is runs for quite a while, sometimes people have said the engine is still running. I did post this on the forum and it was said it is regenerating.Yesterday my neighbour said its the electric fans running , not regenerating, so what is it really and why. Must mention it comes on after 10 mile shopping run to 80 miles at 60/70 mph.
Went to my Skoda dealer this morning. Investigate engine not reaching temperature. Remove coolant cap and run up engine. Carried out diagnostics and unable to establish fault. No errors found. Carried out road test after bleeding system and using odis. Got into car and found everything normal, cost £60 for testing. Now my trip to Skoda the gauge was still at zero. Thanks for your replies.
Again many thanks
Thank you
Drove ten miles and no warning lights came up , so engine could not be over heating am thinking. The hoses still not getting warm.
Got the engine running and felt the top pipe which seems not only cold but empty!
Looking at my thermostat reading and found it was at zero. put my heater on and it did not become hot. Checked the expansion bottle and all is well there, apart from running the engine where I thought I might see a flow but that also did not happen. October 21 had cambelt change with the usual pump etc and that was 7000 miles ago. Any idea what has gone wrong?.
On one of my forums re camping there is a comment about Adblue being used , which I must admit did not know anything about it. I do remember motoriback in the nineties when abroad motorist were adding additives to their fuel. So how many are you using it?
Newbie Caravan Towing Question
pastiche replied to richiewill83's topic in Skoda Octavia Mk II (2004 - 2013)
I find that towing at 1320kg gives me a stable drive in most conditions, also nose weight of 75kg . Too excede these figures can make towing diffecult at times, -
false readings on speedometer
pastiche replied to pastiche's topic in Skoda Octavia Mk II (2004 - 2013)
Hi , it is the mileometer reading I am talking about. I did think it was me miss reading it but previous readings were correct . With the mirrors, both were pointing outwards to their limit. -
I have always kept record of amount of fuel taken on, and after refilling this week found some how I had done 1000 miles less than the last time I filled up? and later found both my mirrors had been altered to ex-stream, Sounds daft but is there any way that someone using one of those hacking things do it?
On my trips I often get reading of 68/70 mpg, but last week happened to look at screen and it was reading 70 plus mpg later it went to 80 mpg , so its gone wrong but how do i do it?
In 2017 whilst parked a tipper lorry reversed on to front of car. one rad ,bonnet, both wings. Last week was side swiped . one mirror, one wing repairable, passenger door, rear door. Hope to get it back next Wednesday. .
That is weird only last week my door handle came off when closing the door . Skoda man just pushed it down and it clicked into the bottom half, no screws.
After cleaning our Octy up after the Africa sand that got blown over it I was disappointed how it was getting. So any one used that Armour ceramic polish at £38 or so ?, saw it on U tube and it gives a brilliant look . Also interior shampoo what is found to be safest for the upholstery etc . Thanks.
Rear windscreen washers again
Thank you . I did get it off eventually and also managed to clear the blockage, however I would have liked to lift out the nozzles but again did not want to force anything . So how did you take it out ?. -
Have had Skoda several times to unblock the washer at the rear which they now say £60 a time. Have always used correct fluid and still it happens . My problem is I cannot get the shroud off the spindle to see the jets clearly . Have used large screwdriver gently prise it up but thought if I give it any more it will split , so how do you guys do it ?.m Looking at previous comments on this problem many have had leaks in boot etc but mine is dry.
Today at about 11am got into car and found all; windows clouded up ,. Usually I operate all windows up and down which normally clears them sufficient to drive off, but this time it was inside as well. Even the control panel was misted up. The sun was out and next doors car which is in different position to mine was clear. The outside temp was at 6.5. This is the first time in memory of having this . we live in a area which is supposed to be the driest part of uk.
