Everything posted by j caff
DSG Reset (Basic Settings)
Because 1st gear's function is for moving off from rest on the flat or on a 1in4 gradient and is geared appropriately.
Just use the brakes for the last little bit and leave the box in second, it's not like you're driving an 18 wheeler with a heavy load. You're really doing things to a dsg box that it wasn't designed to be doing. There is a thing called mechanical sympathy.
I know and I can't get him to stop doing it, it's ingrained in his driving. The gearbox is definitely suffering because of it. Learning to drive in a Morris Minor had its advantages!!
I was thinking exactly the same thing. One of my children does that in his manual car and you can hear the gear whining as it's turning at far too high a speed it's designed to do, the driving instructor told me to do it is the answer I get.... It won't be the driving instructor who'll be crawling around the breakers yards looking for a replacement gearbox 😡
Daytime Running Lights with rear lights
I've never seen that happen and I've used Scandinavian mode in all the Skodas I've owned. Did you use a one touch button to activate them, or did you use coding, I'm not familiar with carista I use obdeleven or vcds myself. I leave the switch in auto.
vRS front mud guards - drilling really required?
I may get off my white Irish arse and put the flaps on my superb, I only have them a year.... The 7mm drill is in the car, it's definitely worse I'm getting 😏
Engine Cover Dealer Delete
Or just close the bonnet....
Does look a bit messy alright, it's just we aren't used to seeing naked engines anymore.
Ahhh will you stop being so dramatic, Skoda themselves recommend throwing it in the bin and being a petrol engine it's effectiveness at reducing noise from an already quiet engine is minimal.
Exactly, everything has to be a "thing" nowadays. Lob it in the bin and forget about it. You can always say the engine identifies as being covered....
VCDS options on Superb III
It's very handy I really like it.
Do you have tsr? If you do it will work. I activated it easily using obd11.
New Battery Needed??
Who paid for the alternator?
Can you jump start it from another car to try and get it home? If you get it running put a voltmeter across the battery and see what voltage the alternator is producing. The battery might be beyond saving but an overnight charge off the car with a smart charger might revive it.
Floor matts and other kits recommendation?
Sorry guys but those diamond mats look hideous, they remind me of something you'd see in a tacky stretch limo, I'll stick with my superskoda mats.
No, by image he means take a photo of the battery you have now making sure the info sticker is readable.
DSG reluctant to go into 6th.
There seems to be no rhyme or reason to when it decides to do a regen, mine regularly would start doing one just as I came to the end of long journey 😡, very annoying indeed...
Accelerator goes dead for a few seconds post auto-start
Get it scanned and see are there any faults relating to implausible throttle pedal signal.
Exactly, especially with direct injection as a lot less heat contacts the cylinder walls. Older indirect injection engines produced plenty of heat, MPG suffered unfortunately.
Umbrellas + Returning From The Dark Side
Spend thousands on a car and get cheap over a 25 pound umbrella.... The mind boggles 😵💫 My 21 car had none and no removable light in the boot either I just ordered them from a dealer.
ride comfort - going from 18" 235-45 to 17" or 16". Has anyone done it?
https://tiresize.com/comparison/ This site is perfect for comparing different tyre sizes.
Mine has DCC and road noise is the same on every setting.
Sounds like it's doing a regen to me. Have you had the soot levels checked?
I have your size wheels and tyres on my car and the road noise is terrible compared to my 2019 superb that had 16" wheels. You could try using one of those tyre comparison sites, they give great info.
Coolant temp spike after waterpump replacement
Is it losing coolant? What happens if you keep driving will it correct itself? Sounds to me like the thermostat isn't opening properly after being parked overnight. Next time it happens check to see if there's hot water going through the top hose to the radiator.
