Everything posted by mrgf
Changing Ignition barrel, immobiliser issue
Many things need coding so perhaps that could be the issue. I was told many years ago, that a Toyota Yaris, if the keys were lost or something, needed a whole new ecu, ignition barrel, door locks, etc, at a cost of over a grand! Turns out not to be actually true-it is just the official way to go but you may just need to code the new barrel to match.
Centerlock not working
Are you meaning central locking? Have you inspected the wiring inside the door loom? Inside the rubber bellows, wires have a tendency to snap so this often causes issues with central locking, windows, mirrors, etc as they all have wires going through there. look in both front doors and repair, if necessary.
How to get brake disc size?
Also, It might be worth checking on Eurocarparts or carparts4less, as thy may offer the correct size straight off. They CAN offer differing ones but its worth a look and is easy to send back if they send you the wrong stuff. Bay can be a PITA for that! (Be sure to use an online code, to get a big discount on list prices).
Where to find help on Skoda broken parts
Problem is, its a common-isn issue and quite minor... Wear and tear, etc so asking the seller if (A) They even knew about it or (B) Will they pay to rectify it as a fault, is unlikely to be met with much more then a wry smile and an "On your bike" attitude. It does not affect the overall performance or function of the car. There are a couple of lower pegs in the compartment, so you could use them if you only have a very small amount of objects in the car and perhaps have a look in the under boot area, where the spare goes, to see if the plastic lugs are in there somewhere. If so, you might be able to drill a small hole through them, pop one of those cavity plug type screw-thingies (Toggles) Through and in to the hole and let the screws flanges expand, screwing them up to a reasonable tightness. Filling the gaps with additional epoxy glue or something similar, will help strengthen this job, as you finish tightening. Be sure not to obstruct the rear seatbelt mechanism, which sits behind there, somewhere. If you can't find the plastic bits, perhaps you could fashion something similar out of doweling wood, slightly thicker then the hole, drilled, fixed and rubbed down on the outer edge, to fit the shelves bracket diameters. A lick of black/dark grey paint will hide it to a degree where only you will see it and you will be pleased with your "Heath Robinson" fix, at an almost non existent cost! (I got mine to do)!
Few repairs and mods...
Easily replaceable centre caps can be had for a similar price to the stickers and are not hard to swap. The beauty is you can revert to the older ones, should you wish. The caps just pop in/pry off or pop off from the rear, if the wheel is off the car. Auto lights have gone cheaper too, of late. Be sure to get the correct switch if buying seperately. Some come complete, some need the switch and you may need to check the size of the plugs. (I had to sell on an auto light controller as it was the wrong size, prior to fitting mine). I have an original Skoda switch from a Yeti, I think, which is the correct colour for Skoda. VW switches are usually red lights, Skoda are green. You could change the window switches for ones with the little chrome bit for a modest cost, looks a little nicer.Sunglasses holder for the roof, where there is usually just a blank panel. Nice little touch is buffers for the grab handles, that make them go slowly to the roof, eliminating the "Slam". Simple, cheap mod, there! Any soundproofing you can do will be nice, if you plan to keep driving it. Under bonnet cover, if not already there, plus many others you fancy. Centre arm rests are nice on longer journeys and can sometimes be found on eBay for around £50 for a genuine one. I wouldn't fit an aftermarket one, myself.
Fabia mk II seat options
I get that, Tommy, it'll be like going back to the 70's... That said, I doubt a head rest so low as to poke the bottom of you skull, will be any better. Might even exacerbate the situation! Have you toyed with the idea of getting someone to fabricate longer headrest poles, (I doubt there is enough on the poles just to grind additional slots to lock it in place but you never know) and swap them over? You would need firstly, to see if there was room inside the setback, to accept it when lowered, though, unless you had the adaptation done to a spare. You would only really need to do it to your seat, unless your family/partner is tall or you ride as a passenger frequently.
You could, as a last resort, take it right off. Keep it handy for resale, etc.
All headlights failed!
Funnily enough, I had the same thing happen recently... Both front LED'S (I know, but I like them. They look nicer and seem to shine on the road better and I have never had the oncoming-driver-flashing-the-lights-a- me scenario) Went very dim. The little fans were still working and they had a tiny, sidelight-like output so it clearly not a fuse related incident. Swapped them out for a pair of non-fan LED bulbs that are meant to be smaller in size, with a bigger proportion of heat-sink metal, so no need for the cooling fans. Time will tell if they last.
