Everything posted by Tech1e
Engine bay missing parts?
/\ /\ This all over /\ /\ The cars that come with the piddly 44 Ah battery always benefit from stepping up to the circa 60 Ah batteries from the TDI models. I popped into Halfords the other week to grab a battery for a friend, was in a bit of a pinch and was my only option. Her Fabia 1.2 TSI had a sub 50 Ah battery listed, I hadn't seen the car but wasn't overly convinced. I grabbed a Yuasa (5 year warranty) battery in the next size up, with the trade card discount it price matched the smaller sized battery anyhow.
vRS engine ticking noise
occasionally
Service Kit
- Service Kit
Most of the dealerships I have worked at have always been very conscious of a new sump plug and torque to 30 Nm, then mark to show torqued (and rightly so). On one of my less than co operative days I had a 19 mm spanner in my hand and thought that will do. My apprentice quite rightly pointed out that I was not doing it correctly. I assured him I had an age old fracture in my right forearm that opened up at 30 Nm, so when I could feel a sharp pain in my arm, then I knew it was tight. He was amazed and commented how handy that was.- Fabia 1.9 2008 various issues
What is the voltage if you move the negative test lead to the other end of the earth cable?- INTERIOR LIGHT FUSE??
And the switch is in the correct position?- Power steering
Needs a diagnostic check ideally but a failing battery would be a good place to start,- Need to know this module name.
Valve block is its official title, but quite often refereed to as the vacuum box. Doesn't look like a MK1 Fabia.- Topping up brake fluid.
Injector controls? As mentioned previously, I don't generally top up the reservoir, if it's got a leak, sort the leak. But if the level needs adjusting we would usually use a syringe.- EPC light car wont start.
You can tell without even diagnosing it? But then rattle off a list possibilities that require diagnosis lol Also I am not your ‘mate’ and don’t appreciate the aggressive tone.- advice needed; Octavia locking nut key
Cheaper for them? Guess it depends if the dealer is local or not.- advice needed; Octavia locking nut key
Why don't they just order a replacement key? Unless they are non genuine.- Skoda fabia mk2 Vrs Mods (Cheap)
I supply and fit for £330.- Tech1e’s ‘new’ Fabia - Slayer
A few phrases come to mind while tinkering this weekend. "Listen to your own advice" "Buy cheap, do twice" When rebuilding the front hubs I bought a pair of ebay cheapy front bearings. 50/50 chance that they will last and that proved spot on. After only a few hundred miles in reality (due to lockdown) the left front wheel bearing started grumbling. So I fitted up a spare hub with a decent FAG brand wheel bearing ready to swap over.- Topping up brake fluid.
Most of the time you shouldn't really have to top the brake fluid level up. It doesn't (or at least shouldn't) go anywhere. If the level has dropped it will be as the pads have worn down (or a leak). Replace pads and the level will be back up, if you top up while the pads are low you will have to remove fluid when they are replaced.- EPC light car wont start.
A fault code check would be the way to start rather than all this guessing.- MK1 Fabia workshop manuals
- 7,992 downloads
- Version 1.0.0
Various Fabia workshop manuals from yesteryear Use at your own risk blah blah- MK1 Fabia - Replacing the front window regulator
Hopefully a useful guide to replacing the window regulator on the MK1 Fabia. MK1 Fabia window regulator.pdf- MK1 Fabia - Aftermarket stereo installation
New Fabia picked up yesterday. Cayenne orange yet again, full service history, two new tyres and in very clean condition. No plans as such other than a good service and the usual bushes. Needs a window reg so I’ll do that with a new ‘how to’ for the guides section I think.- Skoda Yeti Black Edition
- Retro fitting Cruise Control
As many of you will know, I have been retrofitting cruise control to VAG vehicles for over 20 years. From the early days on the MK1 Octavia to pioneering the Fabia install (for those that remember Fabia-vrs.com) before the kits were available off the shelf. Cruise control is retrofitted using new genuine parts (unless otherwise stated). Up until I left the dealer network three years ago, I was a fully trained Skoda Master Technician. I have a full version of VCDS and can carry out long coding. Example prices of drive-in, cruise-out retrofitting Octavia 2 £120 Octavia 1 and Superb 1 POA (check for parts that will be required as kits are now obsolete). MK1 Fabia £220 (all vRS models possible, require checking the level of the central electrics control unit for other models) MK2 Fabia >2009 £260 MK2 Fabia 2010> £350 Kits kits now discontinued Non-Skoda VAG models are also catered for. Ask for details. Fitting takes place at my unit near Worcester on Saturdays. For further information drop me a PM. Many thanks Ross - Service Kit
