PetrolDave
  1. Risk assessment, mitigation and avoidance are great skills to learn and apply especially when dealing with potentially dangerous or lethal items.
  2. With the second largest GHG emitting country Emissions Database for Global Atmospheric Research saying it's a scam I suspect it will be much harder to convince Joe and Julia Public in any country to make their, however small, contribution to reducing GHG emissions. That's the clear and present danger of the new US policy for us all.
  3. I'm interpreting this to mean policies of any Government since this is a global issue. The new Trump led US Government has openly declared that they will withdraw from the Paris Agreement, roll back the Biden climate initiatives and expand fossil fuel exploration (the phrase "drill, baby, drill" has been used frequently). Some of these changes have already been actioned on the very first day of the new administration by Executive Orders. Be interested to hear peoples opinion on this policy and what it means for the global climate 'consensus' now that one of the biggest emitters of GHGs has pulled the plug on climate change actions.
  4. Is that by Skoda UK or the Skoda dealer?
  5. I understand as my GF was born in Plymouth and I used to live in Southampton and work in Portsmouth (so am familiar with the phrases "Pompey Lil' & 'Scummers'!).
  6. Not true, mit silikat was originally fitted on ALL engine versions.
  7. Debatable what the relative merits of those ports are: Southampton - major container port, major cruise terminal, ferries to France and Isle of Wight. Plymouth - major Navy port, ferries to France. Portsmouth - major Navy port, ferries to France and Isle of Wight. Poole - ferries to the Channel Islands.
  8. Yes, they also used to do a set just on a card not in a box.
  9. Halfords sell a set of triple square "sockets" - I've put it in quotes as they're not a socket but the thing that goes into a socket head on the bolt.
  10. Which is quite normal if you e.g. have Normal selected and have tapped the gear selector back to select DSG Sport mode, then the infotainment mode will show Normal but the instruments will show Sport. I quite often do this when overtaking, then when back on the correct side of the road tap the gear selector back again to return to DSG Drive mode.
  11. Car mode (Eco, Normal, etc.) is NOT the same as the transmission mode (Eco, Drive, Sport). Go into Indvidual and you will see a long list of mode options for the different systems.
  12. I've had emails from VAG dealers (Skoda and Audi) advising me that cambelts needed to be changed on cars with engines that had chains not belts - so don't believe anything the dealer tells you!!!
  13. Briefly open and close the door, then the lights will stay on for about 10 minutes or until you turn the ignition on.
  14. In the 1990's SAAB claimed that the exhaust emissions from a SAAB 9000 in cities contained less NOx and HC than the intake air, so greenwashing isn't a new phenomenon. There are many matches on Google, here's just one Reducing Tailpipe Emissions: Clean SAAB 9000
  15. Are you asking about a firmware update or map update? If firmware you'll need to provide more information, specifically the current firmware version.
  16. "Nearly all" is not the same as "consensus". Surely you're not suggesting that wikipedia is a reliable source?
  17. Climate change has happened over the millenia (as can be measured by e.g. CO2 concentrations in rock samples, radio carbon dating of organic samples, etc.) and historical records of e.g. Romans growing Mediterranean grape varieties at Hadrians Wall forts and the Middle Ages mini Ice Age. CO2 levels are not at their highest in Earth's history, during the period of the dinosaurs there is some evidence that CO2 was at around 6% - hence the huge vegetation growth and large vegetarian dinosaurs. What's still debated by some is the relative effects of natural cycles vs human activity.
  18. On the FL models is the indicator still a bulb (as the pre-FL) or part of the LED strip?
  19. You've just opened a whole new can of worms. Is a source that's funded by a commercial organisation dependent on oil/gas reputable? Is a source that's funded by a commercial organisation dependent on renewal power reputable? Both of those will tend to fund only research that produces the "right answer" for their commercial interests, so some would say any research they fund is NOT independent and hence could be argued not to be "reputable". Truly independently funded research which will report what they found without bias is incredibly hard to find now that most Governments have abolished or drastically cut back on non-commercial funding.
  20. You don't tell us what engine you have so it's impossible to confirm or deny that statement.
  21. It says ZR+/NAV - the slash means WITHOUT.
  22. I've never had to top up my 1.8 EA888 between services.
  23. That's an assumption, there are other people who share @EnterName's opinion.
  24. I have a 2016 Amundsen which doesn't have the SIM so I'll have to let someone else answer that.
