Everything posted by numskull
Drivers aircon/heating slower than passengers?
Nice one!
Yes, give that a go first. Try the second if that doesn’t improve matters.
Hmmm. Not sure, but there is also the flap relearn procedure too which as follows @ApertureSis this OK to try to solve Graham’s issue? Turn the ignition on, then off. Hold the ac and recirculate buttons till the panel starts flashing, then all the flaps will move and relearn their positions When the display it stops flashing, cycle the ignition again. Graham, wait ‘til AS comes back with the confirmation to go ahead, or not!!
Grotty Screen - Help Needed!
Need some help over here!
Grotty Screen - Superb 3
Please look at the attached video. Does anyone have any idea what the heck has contaminated the windscreen? This causes the wipers to squeal insanely as it reaches the end of its travel; it’s driving me nuts. As you can see from the attached, I’ve tried removing whatever it is with a Brillo, Brillo and BKF and just BKF. Also I’ve used neat windscreen wash, ISO and acetone. So if this was the usual traffic or diesel film it’ll be gone, but nothing has touched it. All suggestions gratefully received. EDIT Oh BTW; you need to have the sound up! IMG_0220.MOV
You could try a reset, Graham: you do this by holding the auto and face vents switches down together for 30s or so.
New to ownership, finding a few issues …..
Three days gone and no response. Must’ve solved it….or sold it.
Demister Flap Fan Motor Replacement
….and take a 2nd mortgage to pay for it…😖
Air vent tabs
Oh Graham, for heavens sake, just give it a go for £8 then you can tell us if they fit! 😂
Seems like the AC is on, looking at the OP’s pic, John. Just noticed the engine revs seem a bit high, especially as the engine is up to full temp? Isn’t that the case when there’s a high current demand? (Or it’s in Sport mode of course).
Ours is 7 years old and still on the original too. Given the four 1.8 miles journeys a day it does during term time (I drive a school bus) it gets a pounding, what with the AC on 365, the heated seat, screen often both on in the Autumn and Winter when needed together with full lights always on during that time of year, I think it’s done pretty well. I do shove it on the CTEK charger daily overnight in the winter though so that could be helping.
Part missing from windscreen washer bottle, need help
Well, I’m guessing the clue that something is missing, is the huge hole in the tank where the upper pump should be?
Welcome to Skoda Becky10. Tell us some more about the car. Petrol or Diesel? Did you buy it from a Skoda dealer? What’s the mileage? Did they supply a print out of the service history? How many owners? As for the weirdo stuff, certainly a duff battery can make it do all sorts of strange things, but in any event, I’d be standing on their forecourt first thing on Monday and getting a courtesy car til it’s fixed.
Retro fitting LED DRL bulbs
Welcome to Briskoda. You can get LED’s to replace the 382‘s and definitely get brighter Halogens than those you’ve got fitted, however they will be expensive. Take a look on Powerbulbs. They have a massive range of all types at good prices.
That pic you’ve taken is the bottom of the tank, correct?
diamond cut alloy corrosion :sad:
Yeah…. ‘course it does… not. 🙄 Is there any rim damage on any of them? Here you go. This is one Alan refurbed about 18m ago. It had the same issue you’ve got and now it don’t! Needs a full diamond cut… sheesh.
Hmmm. I’ve never had to have them fully refurbed as damage is localised. I’ve no idea where you’re located (it’s a good idea to add that info to your profile; helps in cases like this!) but i use a local mobile guy. His business is called Wheel Doctor, but I’m sure any mobile refurb Co with good reviews or, better still, a personal recommendation, would do just as good a job. The worm is caused by water getting trapped under the clear coat and staining the alloy. It’s a simple case of removing the clear coat and polishing the stain til it’s gone, then re-clear coating the entire wheel. Incidentally, the worm was located in exactly the same place as yours.
Lubriplate 105 will do the job; it’ll never dry-out nor become sticky or hard.
IV - Non Skoda class 2 charging lead being blamed
Whoops… dupe post!🙄
Jeez! I know @ApatureS has removed his dash (and everything else come to that) and he’s a tech too, so he’ll probably know.
AC service
Blimey that’s almost as much as the repair cost on ours! Ker-chang!
Garage full of goodies!
Yeah, but it’s good to have those “real” ones, where the person undertaking the work can show the “real” time it takes, the pitfalls when removing the OE kit, installing the new and how to avoid loosing a thumb along the way etc.
Sounds like another non OE part being given the blame when, in fact, they don’t have a danny what’s wrong.
That’ll be a nice few days work! GL with that and LF to the thread. Be interesting if you were to take a few pics to show the replacement process of the kit, especially the shocks.
AC service
And on the basis that my system was making odd hissing sounds, I got a airco “specialist” to come to me and he said it jest needed a regas and two days later the noise returned. Dammit. Should’ve listened to SJ above and others who said said it wouldn’t be low gas. Anyway, I mentioned this to the Indy dealer I use for service when I was there for an oil change and in 2 mins they found the pipe leaving the condenser had leak. To be fair, the “specialist” refunded me the £120 he charged. And to top it all, when I took it in for the AC to be fixed, they found the water pump housing was leaking! Bloody expensive month that was!
