Everything posted by softscoop
Turning on Bluetooth via VCDS?
No if you have a bolero it will need an extra Bluetooth module and microphone.
Extra Maxidot options?
If you have a maxidot dash cluster, installing a factory sat nav will send that that data to the cluster. It's also possible to just install the compass module separately. Whether you'd be able to find one and the associated wiring is a different matter.
Bluetooth problems 2011
Try disconnecting and reconnecting the Bluetooth module. It should be under the driver's seat. If it's not in the menu on the maxidot screen, it might be that the car has lost the coding that Bluetooth is fitted. A scan with vcds or other diagnostic tools should be able to tell you.
When you can see the Bluetooth on your phone, what name does it come up with?
Superb MK2 Front parking sensors upgrade kit
I still have these. Price reduced to £75 posted.
DSG Thermostat
I never found the hoses brittle, when I did this job on both my superb and Sharan. A set of hose clip pliers make the job a lot easier than struggling with the spring clips
Loss of power
Sounds like the common issue of sticking variable veins on the turbo, making the car go into limp mode. It can usually be sorted with some Mr muscle oven cleaner. There is a guide on here how to sort it.
- Silentstorm
SOLD 4x 16" VW Dover Wheels and 205/55/16 All season tyres
No sorry they've gone a while ago and I forgot to update this.
- Instrument cluster swap
Sunshades
I'd definitely recommend car shades. Yes they are a bit pricey, but they are better than tints IMO as they allow you to open the windows and they are still in place. They also have a value second hand when you sell your car.
Octavia VRS mk2 digital speedo?
There are a couple of similar devices to the polar fis, there is a FIS-control unit, but again it's quite pricey. You might be able to get one second hand. There is the other option of retrofitting a maxidot cluster from a facelift car.
On a 2008 it's not possible on the standard screen. You can buy a PolarFIS that gives additional driving data on the screen including speed, but they're not cheap
Very LOUD Reverse Sensors!
If it was just on top of the trim, no wonder it was so loud. Even the aftermarket kits are designed for the speaker to go behind a piece of trim.
If there is nothing on the bolero display then it looks like an aftermarket kit has been fitted. Some foam over the speaker sounds like the easiest of solutions. It might be easiest to drop the headlining slightly from the boot opening of the car and find it tucked up there.
When they're active, does it show up on the screen of the bolero? If they do, the PDC volume should be a setting in the maxidot trip computer.
Most reliable Octavia diesel/petrol ?
If looking at the 1.6 petrol MK2 Fabia, just be aware of how much they are in road tax due to the high co2 output.
As this is in the MK2 Octavia sub forum and the OP is talking about PDs, the youngest PD will be 15 years at this point as they stopped them in 2010. Even the youngest MK2 Octavia will be 12 years now as they stopped making them in 2013.
If he's traveling for work, will he be driving anywhere with a ulez? There are a few around now and it's one thing to keep in mind these days whether a diesel is worth it.
DSG Thermostat
It's a common part across all of VAG, so VW, Audi, Skoda etc. Just a quick search found a supplier in NZ. https://www.harryseuro.co.nz/products/thermostat-auto-gearbox-1k0121113a Pretty sure there will be plenty of others if you search for the part no.
DSG Thermostat
It's a pretty easy part to change yourself with only a few basic tools.
Open to reasonable offers on this.
Pd swapping a petrol
If you're in Ireland, surely it would be far easier to just buy one in the UK and drive it over on the ferry? The amount of work you'd have to do to swap everything over would be not really worth it.
Electrical interference on DAB radio
It's pretty common for dashcams, cigarette power adapters, and even hardwire kits to cause DAB interference. Try fitting a ferrite clip on the cable to reduce interference.
CD player options
Something like this would probably work. https://amzn.eu/d/0SSn9Cy CD player with FM transmitter. Set to an unused FM frequency and you can then pick it up via the car radio. No need to try to pair Bluetooth or anything.
