Everything posted by varooom
Hello from Northamptonshire
Glad you're enjoying your new car, welcome 🤗
Correct oil Fabia 1.0 MPI 75PS
Yes, it's called erWin Skoda. You can create an account and pay for 1hr access, you can download as much as you like in that hour. Tip: Make sure you can get a whole 1hr done without any interruption as the timer is strict. Have your VIN typed out in a text file ready to copy/paste into website. Grab all the PDF documents, don't slow down to read them, then you can use your VIN to peruse "ElsaPro" to view/print to PDF any recalls or known faults.
Amundsen MIB2 Firmware Update
I can send you 0369, but ideally you should verify your Software Train information first. Yours should be MST2_EU_SK_ZR_P0359T Available MST2_EU_SK_ZR_P0369T
Morning, press and hold down your Setup/Menu key for about 10 seconds to get into the engineering menu, this has Software Train, and also the correct firmware update button. Odds are, you can update to 0369 version.
Door mirror indicator repeater part no
I have done the VIN filtered search, and it seems you have the original part mentioned fitted. Oddly doesn't look like yours, but you either need to get old one off, or opposite side if needed (part number will be 99% same, just 101 / 102 for left/right for example.
Spark plugs
Don't worry, it happens to us all from time to time, brilliant introduction for sure! Sounds like you are looking for service parts, good luck,
I will check tomorrow with your VIN @StuartA to make sure this is the correct part... https://www.ebay.co.uk/itm/255811681927 This should be the part number, the eBay link, use it for image purposes for now. I have not looked around to see if that is a good price, they are almost £39 from the dealers to give you a figure to get under! 1Z0 949 101 C
Spark plugs
Not sure diesels have spark plugs 🤔 Do you mean glow plugs? Welcome BTW.
If just a bulb, then it's W5W iirc, what I call a "peanut" bulb 😁
Might need a daytime shot, if not send PM with full VIN. I can decode it, if you give me a little time.
Yes this is how I read it also, it's best if you can compare the image above to opposite side.
Update Amundsen Sat Nav
If you want to play it safe, copy all files off the map card to a folder called Map-Old. Then can delete all the files on SD card, beware a format could adjust cluster sizes. Now you can extract using say 7-Zip software to the drive letter that's for the SD card. Make sure you do this on a PC.
Hello from North Staffs
The new car sounds nice, welcome 🤗
Software Updates
You can use the same process to bring up software train, looks like MIB3 unit to me.
Software Updates
I am not sure if that car in the picture is using the same software train? No change logs from mothership, only via reading the TPI documents can you guesstimate what is fixed.
vRS Engine Cover Recall
06Q 103 925 K has a STOP ALERT, meaning don't use (and remove ideally) I am not sure if I am missing something, but the part that was stopped and recalled has an oil fill port hole as seen The above cover is not going to fit.
Low battery warning Key fob
The car will have all 3x keys stored, and when he would have used keys 1 & 3, during a low battery situation, the car would store that just those 2x ID's are having a low battery situation.
TMBGB61Z972 1Z is chassis main type of course, the 9 is an internal code, the 7 is the year code VIN filtered by 1Z - 7.... @MikeTheThinker Just need to know if the image above is what he is after, looks like a wombo combo unit to me? But not seen one in the flesh.
Got delayed a little, try to check out these choices. Exploded part diagram, I am sure it should be this part seen if I have got your request correct for the bulb under wing mirror. 1Z0 949 101 D I think this is your likely PR Code, but of course I could be wrong This is what the part looks like, it should be same on other side in mirrored orientation
You need to post your VIN (remove the last few 6 numbers) as there is 1U or a 1Z chassis option
? Appalling Aftersales Service ??
Was then about to say, read page 328, fastball @langers2k once again. p.s. I would say thank you for your effort in trying to assist @johnboy60 the OP.
Thanks @langers2k I was thinking it had to be something stupid like that. I did try to crawl around some of the URL's, but doesn't do much at all. I think the PDF only exists in our dreams sadly.
Can you do a print screen or use Snipping tool to capture a screenshot and post here? I am also getting German login (can change url to en-GB language) but then it still asks for email address and password.
Amunsen MIB1 Firmware
S00.1000.17.99 release = "MHIG_EU_SK_K1552" MUVersion = "0411" There is this update available, so will send you a PM with link
It does say in the manual it should warn you of low batteries, but the car could have stored the fault codes from before that were not cleared out. It might be a software glitch, where it has not appeared on the screen if this is a new fault. Manual states that the range should be around 30m (if the local "noise" is not too great) When the range is under 3m, then you should replace.
