Everything posted by MikeTheThinker
Octavia mk2 unstable swerving left to right at 60MPH+
One other quick check; swap the front wheels over and see if the driving behaviour follows the wheel or stays as-was.
That suggests your tracking is out, perhaps adjustment, perhaps wear on the various suspension elements. Were it mine, I would get the tracking checked.
A quick check for you; look at the tyre treads to see if there's any uneven wear, plus check for the correct tyre pressures and enough tread depth..
2009 Mk2 Octavia Alarm Draining Battery
Our Indy did just that on one of our Octy 2s. Car is still running fine with no problems. BTW look on aliexpress.com for a new alarm; between 40-50 squid at last look.
Photography Thread
Name of Claude, perhaps?
Looking for a 17" Steel Rim
I am embarrassed. I've just checked HERE and my 2007 Octy 2 has 5 X 112 PCD, NOT 5 x 115 as I had in my notes. So, if the wheel is of use, it's yours. Do check first that a full size wheel and tyre will fit into your wheel well, in case it's been tailored for a smaller-sized spare. I'll go measure the externals on this wheel and update you later.
Could high oil level cause my engine runaway?
From a problem solving perspective I would do this - and nothing else - before testing the car again. If you 'fix' allsorts and the car works OK you will not be able to identify the original problem uniquely.
OCTAVIA MK II. - 1.6 BSE engine won't start
My brain was telling me something could be amiss when I watched the vid, but I couldn't work out what it was. Hopefully you've caught it.
The wheels are Pegasus (see HERE ) and are 5x115 PCD. Cost? Whatever it costs me to ship it dahn Sarf :)
I have a 17" alloy wheel that I swapped out from my Scout. Any use?
Photography Thread
That looks like a California Bay - although I don't think the climate is warm/dry enough for those over here.
2010 fabia tsi bcm issue
Was the door in question the driver's door? If so, take a close look at the wiring harness from the B pillar to the door to check for broken or shorting cables or plug/socket pairs not making good contact.
Photography Thread
Very 'Bronte' ...
Front Wiper motor and linkage-compatibility with Mk2 and other VAG systems
I don't know this for certain but when I searching for a new 'base' I could only find the lhd option; searching for the rhd version (1u2 instead of 1u1) I drew a blank. If that's a correct understanding you won't find a new one (unless you're lucky and find an NOS one) so you'll have to check on breakers for a used one. @Dean is a good source of mk1 info; hopefully he'll step in.
Take a look at the parts catalogue entry for a 2006 1U Octavia wiper assembly HERE. It only lists one part, offering no differs for VRS but there are two variants listed for the "base", 1U2955603 and 1U2955603C. The letter suffix usually indicated a revised version. The fitment guide on THIS page says the same part fits Octavia, Audi A3, SEAT Leon and SEAT Toledo. Which part do you feel needs fettling?
Photography Thread
Is anyone interested in a collection of slide carriers? My Dad used to take lots of slides but these are now surplus as I scan the negs. It would be a shame to just tip them; I've tried local 'free' groups but no takers.
Weird starting glitch
Has the starter solenoid been checked for continuity when activated? The 'tick' is the typical solenoid engaged sound but doesn't mean it's making good contact via the starter terminals.
Photography Thread
I have to go there! I love the way the roofline flows out from the rotunda and out along the trackline.
Dying alarm battery 🪫 (MK2 Octavia)
I just checked out of curiosity and they're back on aliexpress. Priced from about 40-60 squid but the real thing. https://www.aliexpress.com/w/wholesale-1K0951605C.html
Octys by & large tend to just keep going. There are known weaknesses but as long as you pay attention to maintenance they're pretty reliable. As regards your copilot's predilection for 'third party objects', mine has been driving for 40+ years and seems unable to avoid such interactions - typically once every 6 months on average. All cosmetic, none serious but still a PITA for insurance and for me (as I have to fix the 'adjustments'). Anyone have a Mazda 2 front wing going spare?
BTW here's the contents of a post I made back in 2020. I didn't save the link (duh!) so you'll have to suffer the repost ... VAG (Skoda) alarm unit 1K0951605C If your alarm is faulty and needs fixing / replacement here are some options: 1) new. cheapest via aliexpress.com from £40, delivery 2-8 weeks normally. 2) used, ebay or direct from a breaker, from £20 or so BUT the battery may be duff just like your existing one. 3) DIY fixit and replace your own battery. A do-able DIY job with care, details available on Briskoda or the web. Problems: getting hold of a suitable replacement battery and not finding the old battery has leaked inside the alarm and killed part of the electronics I will update with links to fixits anon. Fits most VAG vehicles Parts diagram for MY2008 Octavia https://skoda.7zap.com/en/cz/octavia/oct/2008-419/9/951-951020/#3 Table from skoda-parts.com Part suitable for Škoda Octavia 2 , engines: Capacity Power Code Year 1.2 TSI 77kW/105PS CBZB 02/2010 → 04/2013 1.4 16V 55kW/75PS BCA 05/2004 → 05/2006 1.4 16V 59kW/80PS BUD 05/2006 → 10/2008 1.4 16V 59kW/80PS BUD 11/2008 → 06/2013 1.4 16V 59kW/80PS CGGA 11/2008 → 06/2013 1.4 TSI 90kW/122PS CAXA 11/2008 → 06/2013 1.4 TSI 96kW/134PS CFBA 03/2010 → 05/2013 1.6 MPI 75kW/102PS BGU 05/2004 → 10/2008 1.6 MPI 75kW/102PS BSE 05/2004 → 10/2008 1.6 MPI 75kW/102PS BSE 11/2008 → 06/2013 1.6 MPI 75kW/102PS BSF 05/2004 → 10/2008 1.6 MPI 75kW/102PS BSF 11/2008 → 06/2013 1.6 MPI 75kW/102PS CCSA 05/2004 → 10/2008 1.6 MPI 75kW/102PS CCSA 11/2008 → 05/2010 1.6 MPI 75kW/102PS CMXA 11/2008 → 06/2013 1.6 LPG 75kW/102PS CHGA 08/2009 → 11/2012 1.6 FSI 85kW/115PS BLF 02/2004 → 10/2008 1.8 TSI 112kW/152PS CDAB 03/2009 → 06/2013 1.8 TSI 112kW/152PS 4x4, SC CDAB 03/2009 → 02/2013 1.8 TSI 118kW/160PS BYJ 04/2007 → 03/2010 1.8 TSI 118kW/160PS BZB 06/2007 → 10/2008 1.8 TSI 118kW/160PS CDAA 11/2008 → 04/2013 1.8 TSI 118kW/160PS 4x4 CDAA 11/2008 → 02/2013 1.8 TSI 118kW/160PS CEAA 03/2010 → 2.0 FSI 110kW/150PS BLR 11/2004 → 10/2008 2.0 FSI 110kW/150PS 4x4 BLX 11/2004 → 10/2008 2.0 FSI 110kW/150PS BLY 11/2004 → 10/2008 2.0 FSI 110kW/150PS 4x4 BVX 11/2004 → 10/2008 2.0 FSI 110kW/150PS BVY 11/2004 → 10/2008 2.0 FSI 110kW/150PS BVZ 11/2004 → 10/2008 2.0 TSI 147kW/200PS RS BWA 10/2005 → 10/2008 2.0 TSI 147kW/200PS RS CCZA 11/2008 → 02/2013 2.0 TSI 180kW/245PS RS 245, 6S, 7A DHGA 02/2017 → 1.6 TDI CR 77kW/105PS 4x4 CAYC 06/2009 → 04/2013 1.6 TDI CR 77kW/105PS CAYC 06/2009 → 04/2013 1.9 TDI PD 77kW/105PS BJB 02/2004 → 10/2008 1.9 TDI PD 77kW/105PS BJB 11/2008 → 04/2013 1.9 TDI PD 77kW/105PS BKC 02/2004 → 10/2008 1.9 TDI PD 77kW/105PS 4x4 BKC 11/2004 → 10/2008 1.9 TDI PD 77kW/105PS 4x4 BLS 05/2006 → 10/2008 1.9 TDI PD 77kW/105PS BLS 05/2006 → 10/2008 1.9 TDI PD 77kW/105PS 4x4 BLS 11/2008 → 11/2009 1.9 TDI PD 77kW/105PS BLS 11/2008 → 05/2010 1.9 TDI PD 77kW/105PS BXE 02/2004 → 10/2008 1.9 TDI PD 77kW/105PS 4x4 BXE 11/2004 → 10/2008 1.9 TDI PD 77kW/105PS BXE 11/2008 → 04/2013 1.9 TDI PD 77kW/105PS 4x4 BXE 11/2008 → 12/2010 2.0 TDI CR 81kW/110PS CFHF 02/2011 → 04/2013 2.0 TDI CR 81kW/110PS 4x4 CFHF 05/2011 → 02/2013 2.0 TDI CR 81kW/110PS CLCA 03/2010 → 06/2013 2.0 TDI CR 85kW/116PS DFGC 03/2015 → 2.0 TDI PD 100kW/136PS AZV 02/2004 → 10/2008 2.0 TDI PD 100kW/136PS AZV 11/2008 → 05/2010 2.0 TDI PD 103kW/140PS BKD 02/2004 → 10/2008 2.0 TDI PD 103kW/140PS BKD 11/2008 → 05/2010 2.0 TDI PD 103kW/140PS BMM 11/2005 → 10/2008 2.0 TDI PD 103kW/140PS 4x4 BMM 07/2006 → 10/2008 2.0 TDI PD 103kW/140PS 4x4 BMM 11/2008 → 05/2010 2.0 TDI PD 103kW/140PS BMM 11/2008 → 05/2010 2.0 TDI CR 103kW/140PS CFHC 02/2010 → 05/2013 2.0 TDI CR 103kW/140PS 4x4 CFHC 05/2010 → 02/2013 2.0 TDI CR 103kW/140PS CLCB 02/2010 → 05/2013 2.0 TDI PD 125kW/170PS RS BMN 04/2006 → 05/2008 2.0 TDI CR 125kW/170PS RS CEGA 05/2008 → 10/2008 2.0 TDI CR 125kW/170PS RS CEGA 11/2008 → 02/2013 2.0 TDI CR 130kW/177PS NCZ CRGA 03/2015 → Part suitable for Škoda Fabia 2 , engines: Capacity Power Code Year 1.2 HTP 44kW/60PS CGPB 11/2011 → 12/2014 1.2 HTP 44kW/60PS CHFA 12/2006 → 12/2014 1.2 HTP 51kW/70PS CEVA 01/2007 → 09/2010 1.2 HTP 51kW/69PS CGPA 01/2007 → 12/2014 1.2 HTP 51kW/70PS CJLB 03/2010 → 12/2014 1.2 HTP 55kW/75PS CJLA 09/2010 → 08/2013 1.2 TSI 63kW/86PS CBZA 03/2010 → 12/2014 1.2 TSI 77kW/105PS CBZB 03/2010 → 12/2014 1.4 63kW/86PS CDDA 12/2008 → 1.4 16V 63kW/86PS CGGB 03/2010 → 12/2014 1.4 63kW/86PS CLPA 12/2008 → 1.4 TSI 132kW/180PS RS CAVE 05/2010 → 12/2014 1.4 TSI 132kW/180PS CTHE 05/2010 → 12/2014 1.6 16V 77kW/105PS BTS 04/2007 → 12/2014 1.6 16V 77kW/105PS CFNA 03/2010 → 12/2014 1.6 77kW/105PS NCZ CLSA 12/2008 → 05/2015 1.2 TDI CR 55kW/75PS CFWA 03/2010 → 12/2014 1.4 TDI PD 51kW/68PS BNM 02/2007 → 09/2010 1.6 TDI CR 55kW/75PS CAYA 04/2010 → 12/2014 1.6 TDI CR 66kW/90PS CAYB 03/2010 → 12/2014 1.6 TDI CR 77kW/105PS CAYC 03/2010 → 12/2014 Suppliers (as of 2020-04-02): Skoda-Parts.com 199.94 Euro https://www.skoda-parts.com/spare-part/1k0951605c-alarm-unit-skoda-26590.html Ali Express £40 and up https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20200402034235&SearchText=1K0951605C ebay £19 and up (cheapest only 2 hours left) https://www.ebay.co.uk/sch/i.html?_osacat=0&_odkw=1K0951605C&_from=R40&_trksid=m570.l1313&_nkw=1K0951605C+alarm&_sacat=0
We had a recurring false alarm problem on a previous MY2007 mk2 Octy. Our Indy said they usually just cut the wires as the car was getting on a bit and not a likely scrot target. 'snip' done and all was fine for as long as we had the car (about 4 years) and have not heard of any problems from the new owners (daughter, so of course I'd get to hear!). IIRC the availability of official replacements has dried up (and they cost megabux!); they were available via aliexpress for a while but I haven't seen one on offer lately.
Tow bar
Some helpful links: towbar fitting guides: https://storage.enganchesaragon.com/public-websites/ecommerce/pdf_viewer/web/viewer.html?file=https://storage.enganchesaragon.com/public-websites/ecommerce/Inst/C5803D.pdf
Photography Thread
The Paps of Jura; https://training.isleofjura.scot/the-paps-of-jura/
Photography Thread
Are they the Paps in the background?
