Everything posted by Urrell
- LED cornering lights?
Battery change...
As long as the replacement battery is the same or very near the capacity of the original and is fully charged before fitting it can be replaced without coding. It is now getting about that the coding was just to prove to Skoda that the original battery is still fitted for any claims under warranty. Tayna batteries now no longer sell any batteries with the BEM coding on them.
Help. I have 4 x leaking rims.
I had a similar problem on my Harley Davidson Electra Glide Ultra Classic, the rims where the tyre bead sealed had corroded, when I took the old tyres off I wire brushed the corrosion off and lacquered the bead area leaving them for a few days for it to harden before fitting the new tyres, they have gone from loosing most of the pressure in a week to about 2 pounds in 6 months.
Are they the standard Skoda wheels or after-market? I find it strange that all 4 wheels have become porous. What were they like before you had the latest tyres fitted?
Battery change...
Did you not reset it before you started off?
Importing 2011 Yeti from Europe - any guidance on the speedometer and foglights?
I added a large digital MPH screen to the Maxidot display with a Carista OBDII dongle in about 5 minutes.
Multiple lights went out at once
Could be battery voltage low, are you able to measure it before starting in the morning? Also what engine do you have?
Diesel pinking
I had an engine fault light up, it was no3 glow plug but no glow plug fault light!
- Diesel pinking
OBD2 PORT Light
That's not something a Skoda garage would use.
Diesel pinking
How long has it been "pinking"? Have you had the cam belt changed when it started?
Timing Belt replacement
Most Harley Davidson drive belts are made by Gates, just looked at what mine cost, £345 and that is just for the belt with no pulleys!!!
Squeaking/groaning tailgate?
Adjust the stops, one each side near bottom of tailgate.
Badly Corroded Yeti rear brake discs - is this normal ?
This was on my Fabia with the same setup. Rears get so little use corrosion is a problem. The discs looked OK from what I could see except the inner pad was down to the metal.
Fuel filter 2012 Greenline 1.6tdi
Mine is the same as the one you have taken out.
I read old filter as oil filter sorry.
Transfer Box failed - Warranty Company refusing to pay
Is the oil seal not a component?
2 things, how do you know the housing is 2mm high? What do you mean " I was VERY gentle when prising the top off," ?
Exhaust inspection warning / EGR Valve
Have they checked the car or just been told the ""exhaust inspection warning light on""?
