Urrell
Everything posted by Urrell
  1. Mieux vaut que vous ne mettiez votre adresse e-mail sur aucun forum. 2 messages jusqu’à j’ai mis où vous pouvez télécharger les manuels Amundsen et Yeti dans Français. Il suffit de choisir ce manuel de date et la langue que vous voulez.
  2. You can download Yeti Owners Manuals for car and infotainment system for all years and all languages in the link below. https://manual.skoda-auto.com/004/en-com/Model/Yeti_5L
  3. I moved to a Yeti in 2015 after 11 years with a Fabia Elegance Estate. You will not regret the the move, got into the Fabia after about a year with the Yeti and what seemed like a comfortable car for all that time was surprised by just how good the Yeti is.
  4. Some phones are not compatible, especially the early bluetooth with modern phones. Edit: Have you been into the System Setup/Bluetooth menus?
  5. Could it be it lost communication with the key transponder?
  6. Is it just a pipe pulled off the connection?
  7. As more than one fuse to the radio disconnecting the battery for half a minute is a better option. The recent miles on the trip will be lost but everything else should settle down after a short drive.
  8. Yes, no mention of power steering in either fuse box.
  9. Does music work if connected by USB or AUX?
  10. Urrell replied to boxman's topic in Skoda Yeti
    If an advisory on the MOT it's something that is not going to get better and must be near to a fail. Perhaps it could be saved if some form of protective coating could be applied.
  11. Any VAG mechanics will know their way round a Yeti.
  12. No cables in place so compatible camera will need to be wired from camera in tailgate to head unit.
  13. That is probably the last thing I think that would have caused it.
  14. Flip the covers off sideways and it's then obvious.
  15. At least the diaphragm spring looks in one piece, that normally takes out the gearbox.
  16. It is recommended that the weight of the caravan should not exceed 85% of the weight of the car, ESPECIALLY for anybody new to towing. Edit: https://www.rac.co.uk/drive/advice/driving-advice/towing-capacity-how-to-work-it-out/
  17. You cannot hold down throttle then brake to dry out disks after going thru deep water etc as throttle goes to tickover and it'll stall but pedal feels normal. But if you have a little speed and brake gently first you can then apply throttle and it will respond, brake must be applied first then balance throttle against brake.
  18. The standard 8 speaker speaker system in mine is excellent.
  19. Yours will be a timing chain.
  20. If it is a problem with the secondary latch it should be possible to lift the bonnet to the catch and get something like a long screwdriver to push the catch across at the bottom of the hook.
  21. How do you do that with the bonnet closed?
  22. Is there any resistance on the cable?
  23. That k you added there makes a lot of difference, don't get much for a fiver today.
  24. What garage do you go to 😀
