Everything posted by Guest_
Eco (cruising) - how does that really work ?
Hardly a gimmick when it is enabled and used on suitable roads & it can result in less fuel being consumed. People can get more miles from a tank using 'Coasting' while doing trips in the same time at the same speed as not enabling 'Coasting'. It might well be more about the manufacturer meeting Average Fleet emissions which they need to and the WLTP / RDE2 results but it is easy enough if you do the same trips regularly and throughout the year in the different seasons and road conditions to drive with Coasting Functioning and others times without and see if you use less fuel. That becomes more difficult when it is a car with ACT/ COD and not just a 4 cylinder engine where ECO/ Coasting is about the DSG disengaging.
Stage 1 Remap
Just presuming that you are remapping to improve the performance by increasing the bhp / Nm there is little point running 95 ron Unleaded E10. E5 in the UK is 97 or 99 ron minimum and it would be usual for the remap to be written to suit running Super Unleaded. Sainsbury,s Super Unleaded is 97 ron minimum.
the truth about electric cars
It is done here daily. Tayside Contracts. The 2 guys always are on the go with the jug of tar and a scraper. It is the Utilities Contractors that often mess up, leave jobs sitting undone for weeks, then rush a job and move on. Not the Councils ex department that went Commercial. It is just a case of location location location and i cycled lots of roads and pay attention.
I see the hot tar being poured along the edges all the time. Actually that seems to be the signature. Job done, lets knock off for a while.
Skoda Octavia Estate 2012 model Servicing
No Service Schedule, guidelines or recommendations to change the 2 oils in a DQ200. ? Any record of the cambelt and water pump been replaced. Regardless of anything Skoda / VW says now about their replacements i would not leave one for 12 years. or even 6 years.
@Oluwasegun Is it a 1.6 TDI CR, 7 speed Twin Dry Clutch DSG? A diesel. So VW504 00 / 507 00, 5w 30 FS III even for Fixed Service Intervals. No Service requirements / oil change for the DSG. EDIT, Sorry spotted the TDI at the bottom.
Good road surfaces getting broken up is one thing. It does not take good eye sight to see that the repaired after repaired areas with potholes regularly there is commonly were where the road was dug up by various Utility Companies or by the contractors. Those are not just little business,s doing a crap job, the Local Authorities know who they are or should do.
The Oil is to VW504 00 / 507 00, so 5w 30 FS III. For Fixed or Variable Servicing. It must be VW507 00 if a TDI, Fixed or Variable. For a TSI it can be VW502 00 for Fixed Servicing, so 5w 40 FS. (Not long life oil.) £279 was a fixed price for a Major Service back in 2019 at Participating Main Dealers for a service. After that it because the new Service Regime, where extras cost extra. Little done.
Three G11 coolant mixtures, boiling-cooling time comparison.
I know nothing about science, but i do know that a cars coolant system has a pressurised system for the Coolant / antifreeze / anti corrosion liquid. This raises the temperature at which the liquid boils. When i ran V8,s on LPG i used Water Wetter, So when i ran remapped Twincharger TSI,s i did the same.
Someone will be to blame and if they were Right Wing Tories then we know who supported them. SN00654.pdf
Simple enough to touch the accelerator pedal without accelerating and it is back with gear engaged.
Non Dom Jonathan Hermsworth, 4th Viscount Rothermere, his family and those that own and run his Media Empire probably walk, cycle or just drive around in small city cars or use public transport.
Stage 1 Remap
It is worth looking at the threads already in this section on remapping 1.2 TSI,s There is no cons. Check the servicing is up to date, new plugs & air filter in and run it on E5 and if all is well choose the remapper and be sure your insurer is fine with mods or that you can get insured with someone that is.
41.3 million plus vehicles on the UK roads or parked up and less than 1 million being BEV,s and maybe 1/2 of those or more not big BEV,s.
Elephant in the room / on roads. Light Commercials, not so Light Commercials / goods vehicles, heavy goods vehicles. Mini Buses. Black Cabs. Busses, Bin lorries.
What are these???
It is the case that hold a folding warning triangle. No idea if empty or not.
Fueling? Issue
Dozens or hundreds of other drivers will have used the same fuel from the same tank at the pumps. So if any question on fuel ask the Filling Station Manager if their tanks were mis-fuelled or others are having issues. Surely they could not lie because of just how easily they can be found out. Social Media, Local Radio, Press. The water and diesel does not mix. Think where the water is in the Filling stations tank if there is H20 and their systems & filters & out take.
Domestic charging points - A new social dividing line?
London might have 8.3 million people or whatever, but charging BEV,s / PHEV,s need not be all about London. The Green Cabinets are being trialled in Scotland and if the BT / Open Reach vans can charge at then and not hog ones the General Public need then good. http://bbc.co.uk/news/technology-67873890 ........... So today we are told that the National Grid needs £58 Billion spending on the Transmission of Renewables. The Cables from the North to the South and the pylons where the Pylons are required. Obviously much objection from some in England that there needs to be big pylons to get the electricity to them. Stuff the fact the big pylons are running from Aberdeenshire south to get the electricity to England when it is going overland. IMO Get them up where ever needed, and have the end user 100,s of miles away pay the cost of transmission not everyone including those that do not even use the electricity from that source. http://bbc.co.uk/news/business-68601354
General question on engine horsepower
Re PS/BHP/kW & Nm. You are paying for what you get and the Max PS/BHP/kW & Nm in the UK is not the max, it is the Minimum you should get. You are not going above 3,000 ft above sea level in the UK, Ambient temps not more than 40*oC and not colder than -30*oC & the fuel is as it should be Petrol e5 or e10 or diesel. (Not true with BEV,s though as if the Temperature / Battery is cold in ambient temps only as low as -5*oC then power can be reduced until the battery is up to a good temp.) As to official VW Group Figures, 0-60 or 0-62 mph, top speed etc. They often lie. A VW or Audi with the same engine, gearbox as a SEAT or Skoda and the same power can be shown as better performing. They do not like CHEAPER cars looking as better performing. (EDIT> Even if the VW or Audi is heavier than the Skoda / Seat. But then the Kerb Weights can also be 'fiction' if you actually weigh the cars.) This was true in late 2015 into 2016 after the Defeat Device Scandal and Euro 5 emissions. Euro 6 Petrol & Diesels were retested / investigated and VW, SEAT & Audi had ERRORS in their Test Results at their favoured facilities. Fuddle not fiddle. Deliveries were suspended, cars withdrawn and even bought back. Now Test Results were then given for some. They are little liars quite often. If the cheapest Skoda is lighter than the estate, and the Polo, Seat (and the Audi A1 5 door sister car even though it is 136 kW & not only 132 kW) which cost quite a bit more and would be a lower or the same VED class than add 'Success Ballast'. Design, Manufacture & Test adding extra weights and stick them only on the Skoda. Others are making cars lighter, VW tell Skoda, MAKE IT HEAVIER AND GO LIGHT UNDER ACCELERATION. Do not just fit the correct rear springs. Vorsprung Durch Technik.
Octavia IV 2021 juddering
Welcome. How many km has your iV / PHEV covered and what servicing has it had. Has it covered 64,000 km? Has it had the brakes serviced. Has it had 3 oil changes and has is been far enough that new spark plugs have been replaced. The DQ400-e DSG is due an oil change at 64,000 km. Is the Air Filter clean / fresh / dry?
Wiring loom; Used Car Warranty
Be sure it is not the loom between the door and pillar. Plenty threads on that and pictures and info on the replacement.
??? Is this Westminster / UK Government grant announcement UK wide & not just England? It does not say. Andrew Bowie MP, Conservative & Unionist, West Aberdeenshire & Kincardine. (Soon the House of Lords when he loses his seat in Westminster.) Energy Security & Net Zero /Nuclear. (Maybe he can do something in Scotland that he has any say over.)
Any concerns buying a 2015-2016 Superb?
If the DSG changes gear perfectly then that is what you want. Only have the place service it if they know their stuff, otherwise get the cost of that off the purchase and have it done by a place that does. Does the 2016 TDI have SCR (AdBlue)? if not then maybe for the better.
Gearbox (DQ381) in Emergency Mode
Just needs fitting by someone that knows what they are doing, or as is only too common it is back to square one. Amazing how many get it wrong.
