2009 Octavia VRS - Fault 006439 - Relay for Aux Coolant Pump (J496)
The one next to F30.
It's the one in position 2 in the engine bay box.
DIY air con re-gas
^ Sounds like the typical direction of progress in automotive tech.
Fabia 1.2 HTP Oil Pressure light flashing
Check the wire that goes to the pressure switch (for damage to insulation and conductor, and the connector for oiliness or corrosion). Fit a new pressure switch if you haven't already.
Interior Light & Buzzer Issue
Points 4 and 5 in your opening post go against that theory though, I think.
I didn't get that from your earlier posts, sorry. I faintly remember there being a transistor within the Onboard Supply Unit that grounds that brown/yellow wire in response to the door switches. I guess that may have blown up. I'm pretty sure I've got a photo of it somewhere, but haven't the energy to look tonight.
Couldn't it be both door switches?
Cam and Crank sensor issues...
For less than £20 you can buy a suitable cable, set yourself up with the freeware version of VCDS on a laptop, and be able to read fault codes yourself. Have you asked the garage what fault codes (the numbers) they read at each stage? Or did they tell you? Could always ask now if they didn't write these down on any invoices. You've paid for that info, really.
Fans not running
Yep that's the positive connection. May need a new crimp on the end of that wire, that's probably what caused the overheat.
Fans not running
Be careful with that 'main black alternator ground' because I'm pretty sure that's the 12V connection; got a photo?
You don't say which 1.2 engine variant this is (54 or 64 bhp?) Sensor failures are pretty rare, so it is extremely unlikely that both were at fault. Cam sensor shouldn't be a big bill; it's very easy to change, and not that much to buy, even for a genuine part. Crank sensor is much more awkward to change.
Morning engine warm for TDI
Probably somewhere in the range 75-100. Watch engine coolant temperature in VCDS during warm up of your car and compare to gauge indication. You'll see it gets to 90 indicated well before the sensor says 90. I've never played with seeing how hot it can get before it reads over 90; slightly dodgy thing to experiment with, cos you'll probably have to disable fans to get it hot enough to find out. It's not a biggie though, anywhere in that range is fine to drive any way you feel like.
Airbox for Fabia VRS 1.9 tdi
Seems to me that the part number you want is 6Q0 129 607 AJ, see entries for item 7 relating to ASZ and BLT engine codes here intake connection; air filter with connecting par... - Fabia(FAB) [EUROPA 2006 year] (7zap.com)
Skoda Scala 2020 Brake Fluid Reservoir
The different position is because the manual shows a LHD car.
Tdi 150cv 4x2 is faster than a 190cv 4x4
Rotating isn't reciprocating.
Erwin Registration
Look under the Individual vehicle information tab, select repair info, model etc.
Sensors in sump
The only one is the combined oil level and temperature sensor which sits through a hole in the bottom of the sump, shown in this ebay listing You'll have to judge whether that might be close to the path of the dipstick or not, but it won't be directly in line, I'm pretty sure. Fully encased anyway, so you'd struggle to damage it with a flexible pipe.
Please help 1.4 mpi EPC light
No, just use the tips of your fingers to feel where your eyes can't see. If there are cracks, your fingers will feel them.
You need to feel as well as look, the cracks often seem to form on the underside, out of view from above.
- DIY Service 1.2 HTP Petrol 04
Check the brake servo vacuum hose for cracks at terminations of hose sections.
The genuine sump plug has a 6mm hex key fitting in my experience, and only requires a replacement copper washer, not the whole thing; unless the hex recess is chewed up by prior clumsiness. Fuel filter you're more likely to create a problem than improve things so I'd leave that alone. You can usually pick up genuine engine air filters on ebay for £10 to save having one come all the way from Berlin, or wherever Autodoc are shipping from lately.
Skoda Fabia Abs light and brake noises
Do you have the same size wheels and tyres in all 4 corners?
Fabia MkII S 1.2 3cyl 70 bhp Timing Chain Replacement Query
No problem. Coilpacks are possibly the most vulnerable parts on these engines, so consider buying a spare, and a handheld code-reader. Keep both in the glovebox then you have a fair chance of re-mobilising yourself if you ever break down due to a failure of one. If you're not DIY-minded and have breakdown cover, it might save a bunch of time by the side of the road if you have a spare ready to be fitted for you.
