Dump Valve Spec, Pls post YOURS/It is a myth that the VAG 1.8T cannot run a blow-off
Forge 007 fitted normally
Standard car 53 plate.
Carbonio air filter
Had no problems after 5000 miles.
Slightly better throttle response and a nice sound !
Andy
2. say maybe denis's age multiplied by somewhere between 4 and 5
400bhp? Pull the other one, Paul...:shocked:
Don't play the innocent with me, young Uildjert :nono:
I honestly don't know what you mean Nick... :confused:
Pls post up spec of:
1.- the dump valve your using RDV/BOV,
2.- car, engine bhp/boost,
3.- any ill effects/limp mode.
Thanks for D replys lads. I might only have 15 post but i no it's not nice to HiJACK thread! If you no all there is to no about DV good for U don't look and move on.
1.8t cannot run a blow of valve. (using VW management)
question answered.
would my 51 plate octy be using VW management??
seem to be fine... :confused:
but i do have an untrained eye, what shoudl i be looking for ? how am i ging to tell if the turbo is not boosting correctly?
Joel
Most likely' date=' unless you or any previous owner happens to have casually mislaid something like a DTA48 mappable ECU under your bonnet.
Joel
Watch out for overtaking milk floats, Reliant Rialtos, Saxos, Novas, Escorts etc etc.
are you saying you use a "vent to atmosphere" DV /BOV?
if so then eventually it will fail as it confuses the ecu and throws the mixture out... unless you have done some other "unmentioned" mods.
Turbosmart dual port
DV has been relocated, now fitted between intercooler and inlet manifold.
No problems so far, been running for four months.
no thats not the kit my DV has been relocated between the intercooler and inlet manifold...you cut a section out of the pipe insert a T bar and the DV connect to the T bar..you then run a vacume pipe back to where you OE DV vacume pipe connected...the other two 25mm pipes connected to the OE DV are blcoked up... and the only other mod ive done is a K&N cone air filter...as far as i know no remapping or diffrent chips have not been put in..
Could it be the they have solved the problem of the octy not running a venting to atmosphere DV?
Joel
1. HKS SSQV
2. SEAT Leon Cupra 1.8T - 255BHP (K04 turbo, 21 PSI, APR map)
3. No running problems at all - zero, for around 6 months now. The sound is AWESOME!!! Ran with zero problems using K03S and APR map too. Located HKS at back of engine and now relocated at the front just in front of throttle body, runs the same with no problems, never stalled or backfired once, no petrol smell - nothing, just SWEEEET sound and no drop in performance.
I tried the GReddy Type-S and that refused to run in BOV mode at all, cutting out all the time, the HKS SSQV is the one.
For those members like me who don't know what an HKS SSQV is, read this.
