Amd stage3?
and the only clutch capable of handling that sort of power is the spec stage 3+ and billet ally flywheel,please have a ride in one which has this mod(ie mine or jasons)as there is probably a really good,noisey,really bad in traffic,and vibrations that will knock your teeth out,reason we are the only idiots with this setup,there are quite a few on here who have ridden in and seen one or both cars,if you are going to the extremes of power then do beware there is a real compromise on comfort,noise and vibration levels,and they are also a real pain in traffic:thumbup:
i got that clutch/flywheel combo in my Octavia. I thinks its very good, smooth and light. A little bit notchy in traffic but worth the gains. Bloody noisy like you say tho :)
Regards
Garry
i've got teh same clutch adn flywheel bolted onto my engine too, shame the engien isn't in the car yet, its still waiting for some more bits :(
Doh...
Can I Just Check Garry, the Fly wheel and clutch combi yourself and benji are mentioning i notice you both have Petrol 1.8t Vrs's, is this the same set up as a Vrs Fabi Oilburner?
Theres an already done up 05 reg one on ebay for much cheapness.
Buy that and save 3/4k pounds
Also for 230 bhp a Helix and SMF is fine :thumbup:
Scotty. Im afriad i cant confirm if the 1.8t one and PD130 clutch flywheel are the same. I would expect them to be different tho being different engines and gearboxes but someone may come along and correct me :)
I should imagine that the drive and caracteristics are the same for the Spec stage 3 clutch no matter what car its fitted to tho, as they are both converting from DMF to SMF.
Hope this helps.
Regards
Garry
Cheers Garry- think i got abit confused with all this uber helpfull info am getting.
gary has a 1.9d and i have a 1.8t, same clutch and flywheel as we have the same gearbox all be it mine has a third output and shorter ratios :)
i believe the difference between mine and Garry c's car is his is petrol,using the billet ally smf in the diesel is what creates the discomfort:thumbup:
Oh and the dogbone mount is a little harsh:D
I really hate my car unless its going fast,its just soooo uncomfortable:O
flywheels are same, 240mm IIRC
thats because they have the same gearbox.
