Felicia 2.0 engine transplant thread
why so??
becuase there is nowhere for it to go...
also another stud directly above the driveshafts has to be removed and replaced with an M12 capscrew to fit in the recess in the bellhousing adaptor becasue there isn't enough space to get a nut on the end of the stud...
can anybody spot any potential difficulties i might face in regards to drivehafts?? :o
edit: it's not an M12 capscrew... it's an M10
Edited by TeflonTom
  • Replies 442
  • Views 50.3k
Im sure the sump could live with a bit of trimmage.
unfortunately just cutting off that lug next to the diff wont give enough clearance for the cv joint, i'm going to have to do a bit of metal surgery on it :o
I wonder if an alternative sump would work?
well, curiosity has just got the better of me, and i've whipped the sump off to have a look..... i thought this engine had no oil in it..... how wrong i am..... well :rubchin: how right i am.... here is no oil in it now, it's all over the floor in my garage :o
i'm so glad the clutch wasn't on there, it would have been ruined.... nevertheless there is plenty of space to play with inside which is good
whats the wepon of chose? 5lb hide mallet, or 10lb sledge?????
i know what id use!
yeah the same thought crossed my mind too ed, but i reckon this would crack rather than bend because it's a casting
good luck tom, That looks like an awesome project.
Keep up the good work.
casting!!!! arr, that means you need some proper bodgeneering. evan a cut-an-shut is gunna be fun!
yeah, i'm going to cut it with a jigsaw then make up some plates to weld on, should be fairly easy..
sump, after chemical cleaning :D
ready for the chop!!
welding cast can be a whole new ball game.
Yeh good luck with that! lol
yes i know, fortunately the vw sumps weld quite well becuase they have quite high silicon content:)
As can welding oily, like a used sump pretty much always is. I'm no welder (as my ex-welding instructor would testify ;) ), but I do know the importance of starting with a clean job, and the difficulty of cleaning oil tanks!
hence having it chemically cleaned before i even started thinking about looking at it:)
you can gas weld an oily job.
i've fixed oil tanks with 4 tonne of oil still in them!!!
genuine vag timing belt kit bought off ebay for £22 :D
sump got the chop today, i know it looks a bit rough but it's good enough:O i now need to buy in some 2 or 3mm ally plate to make some ickle bits to weld on
lol, sump butchery, love it.
Not had to do any of that since we fitted a 4.0 V8 into an E36 BMW, and at least that was a steel sump...lol
nice piece of 2mm ally plate turned up in the post today, £4 off ebay :D... the plan is to cut out the bits i need to fix up the sump using a jigsaw:)
Edited by TeflonTom
big thankyou to pinkskud for doing these for me...:thumbup:
exhaust downpipe flange and egr valve blanking plate for the vag sdi diesel exhaust manifold
i've found an exhaust specialist who makes exhausts for motorcycles who is willing to make a downpipe for me for cash;)
was going to use ready made elbows from jetex and weld them together but there doesn't seem any point if i can do it with one piece, i cant draw up a diagram yet till the engine is in the car though:O
Guest
