16 MPG around town on a 1.6 engine (whats wrong)
Hi i have a 1.6 1998 S Reg Mk1 octavia and recently me and the mrs have been putting more money in the car for petrol we have also noticed this on a run aswell.
When we put the computer display on the dash it says the car is doing around 16mpg in town when at lights and junctions this goes down to 14 then when we get a bit of momentum going it goes to between 16 and 17 :eek: mpg, its the same on a run keeping at a steady 60 its displaying a return of between 23 to 27 mpg :eek:, surley this cant be right for a 1.6.
I know they are quite heavy cars etc but this is a joke and its costing us more to run since we first noticed it around 3 weeks ago.
What could be causing this and does it sound expensive and what should the car be returning? :confused:
Thanks for any help:thumbup:
Forgot to add I dont have a petrol leak :D I have had this checked.
Thanks again
hmm, i know it's a heavy car with a small engine, but even my vRS returns at least 30 when I drive into / around town, usually a 6 to 8 mile round trip..
that does sound quite low, but i would try doing a good a-road or motorway run, with a reset trip computer, to see what it is capable of at it's best.. ?
Mine does 30 around town, too... but the vRS has a lot more torque... but a 1.6 should not be doing half the MPG!
Check your fuel and air filters, tyre pressures... maybe use some injector cleaner?
Could also be a faulty MAF causing the car to inject more fuel than it needs,
Can`t put a finger on a fault,but there must be something wrong,i was getting those figures from a 2003 Subaru Impreza WRX STI type UK running @265bhp,0-60 5.1 Seconds.
Might be worth changing you`re air filter though.....:)
30-35 round town, 40-50 on a run...sounds like you do have problems!
First thing I'd try is to check actual fuel usage (brim it, use some fuel, see how much it takes to brim it again and then work out mpg from that)...might just be something amiss with the trip computer.
If it does look like it's using a lot of fuel, get it hooked up to diagnosis - it might have logged some fault codes indicating that it's running rich or similer...
Rob.
Thanks for the pointers guys, the fuel gauge is going down fast so i know its using lots of fuel, i will have to get it checked out as come to think of it it did smell rich from the exhaust tonight.
when was the car last serviced?
Have you checked Air filter, fuel filter, sparks, oil and checked tyre pressure? and have you tried some injector cleaner like redex? also try a tank of vpower and give it a good thrash approx 30-50 miles and then try reseting the mpg and see how it performs. personally to me sounds like it needs a good service.
Had a friends 2 litre Golf take a drastic incresase in fuel consumption, it turned out to be number 1 lambda probe.
Either way the car needs a good diagnostic test.
How much would the lambda probe be? The car had a full service in april and its covered 4,000 miles since, had all the plugs done, fuel filter, air filter etc.
Does anyone else have the 1.6 engine and what does their MPG computer read around town.
How do you re-set the mpg computer - Thanks again for the poiters.
It smells rich just after start up and then it goes away, always seems to be when you first start it even when its warm.
Bank holiday weekend so cant get anything done till end of next week at the earliesst.
Like Lummox said - you need to get a diagnostic, it will tell you where some if not all your problems originate from. from experience would suspect Front Lambda, MAF, Air filter, as you are running extremely rich. My 1.8t 4x4 driven briskly around town gives 20+
I have a 1.6 and average is 35mpg combined - I last reset the trip overall about 400 miles ago.
The computer works with two settings - one which resets after the engine has been off for two hours (setting two), and setting one which counts continually up to about 10,000 miles I think (unless you reset it). You will notice the little numbers on the top right of the display on the combined mpg, and the duration of time you have driven. It also shows the numbers on a couple of the other screens when you cycle through (but I can't remember atm).
To reset either reading at any time, choose the setting you want to reset, and then hold the reset button (on the bottom of the wiper stalk) for about 4 seconds.
Hope that helps.
About £300 I've been quoted by a dealer - that said, mine's covered about 9k miles with a busted lambda probe and the economy's nowhere near as bad as yours...
Rob.
Lambda probe on my RS was about £100 not sure on the 1.6 but it can't be much more I'm sure.
Yeah, was about £130 for the part then about the same again for labour...
Rob.
Rob.
Sorry I didn't think of labour as mine was fitted free.
£130 labour :eek::eek::eek: It only took ten minutes. My mate was longer waiting for the exhaust too cool than doing it.
Edited by fatty5000
Lol :D Will have to get it sorted - One question i have is does my car have an engine management light as surley this would come on if a sensor was to blame.
My car is 1998 s reg 1.6 glxi - Never noticed a engine management light so if you guys can confirm if i have or dont have one it would be great.
Cheers lads
Not sure...if you have one though, it'll light up when you turn the ignition on and the "self-test" lights go on...
Rob.
lambda probes dont always pull the light on, they become lazy and still work but just not as fast as they should!
I had this some years ago with a MkII Mondeo 1.8 LX (petrol). It returned little more than 20 mpg, despite coming up as "no fault" on the main dealer diagnostics. One of the mechanics suggested changing to a locking petrol cap and guess what - 30-35 mpg overnight!!!
Turned out somebody had been siphoning petrol from cars with easy to open petrol caps / flaps.
I cant seem to see an engine management light on mine when i turn the ignition on i get the oil, battery and imobliser lights on oh and the abs so it appears that i may not have an engine management light whih seems strange. Anyway these bank holidays dont help as i cant do anything untill thursday.
I dont think someone is pinching petrol it just that the car smells rich and trip computer reading 16 mpg round town.
I also have noticed sometimes the ar is reluctant to start (keeps turning over and trying but not starting)
Its like its flooded then after a few attempts it starts but then smells rich.
Maybe this may give an idea what could be wrong, it doesnt do thi all the time just now and again.
Thanks fo the help.
automatic choke sticking?
