front screen washer nozzles
There's a thread on here somewhere about adjusting the aim of windscreen washer nozzles - I can't find it. Can someone remind me? Is it just the usual pin-in-the-hole method?
Easiest thing in the world to adjust.
Lift the bonnet and just raise or lower by hand.
So simple, even I managed it!
no pin required :)
On the Octavia they are the easiest thing in the world to adjust.
You move them with your hand.
Okay folks - I put my glasses on and found it! (It's the memory really - I keep thinking it's a Cavalier.)
dont use a pin, its a fan jet.
Keeping with the jets, my rear ones keep getting blocked and dealer has replaced them twice under warranty but the warranty has now run out.Any idea's why this happens?.
are you using the vag fan spray screenwash? if you use anything else it will block up.
I use tescos own brand screen wash and have done for 2 years with no problems with blocked jets (also used the same screen wash on my last mk 1 octy for nearly 4 years with no issues).
Yes is the answer what i use for screenwash , its the one from our dealer with Skoda etc on it .
Make sure you use the right dilution rate or use the premix stuff , also are you in a particularly bad area for hard water and have you thought about how long it is between refills.It may be of benefuit to only fill the bottle half way
