312mm Brakes upgrade
Morning All
Seen many a thread about upgrading the brakes on the Fab VRS and have seen a locally breaking suitable donor
Just wondering if it is worth bying and upgrading the rears as well as the fronts? Or would that only make handbrake turns would be easier and not a of other inprovements?! :rofl:
****edit****
and which bits exactly do i need.
discs, callipers, carriers, do i need hubs as well? - the breakers seem to think i did?!
Thank in advance
thanks in advance
Edited by PastyBoy
The rear brakes do around 10% of the braking so £ against performance benefit it's not really worth it.
Pleased to read that!:) I've just bought all the pieces for this upgrade but didn't bother matching the Zero60 discs and Strada pads for the rear as I just assumed it wasn't worth it. Im sure the OEM rear discs were only about £50/60 I bought so just gonna stick these on, or the mechanic will I should say! :thumbup:
Should of said in my last post, you only need the following:
Carriers
Calipers (and paint if you wish)
Discs
Pads
From asking the same question I was told the existing hoses and hubs will fit although I was advised the hoses are relatively tight but should'nt cause a problem
The guy that fitted mine used the existing hoses and I havn't had any problems, the brakes were bled a year later and no issues were brought to my attention.
Part numbers for the recommended items are on VRStu's site - Fabia-vrs.com - 312mm Brake Upgrade Kits - but as above you need carriers, calipers, discs and pads.
From what Stu says, hubs are only required if you don't have 288mm brakes (as fitted to the vRS) as standard
Personally i would invest in new discs & pads, Just get the calipers and carriers from the breakers!
What cars were they fitted on as standard?
I know they were on the :
Audi TT
Golf R32
Octavia VRS
But what else? Golf and Leon/Toledo V5? Just that the above cars are more difficult to find in scrap yards.
The upgrade kit thats on VRStu's site is deff going on my shopping list :)
:iagree:
I bought calipers, carriers, discs and pads from a guy who was breaking his insurance write off vRS and when I took them to the garage they said it wasn't worth fitting the discs and pads as I'd only have to change them in 6 months. New discs and pads were about £100 iirc
Audi TT
Golf R32
Octavia VRS
Golf R32 had bigger still, 323 iirc, possibly the golf anniversary you are thinking of.
Leon Cupra
Leon Cupra
Aren't they 323mm (Brembos)
I think the Cupra R 225 is, but not sure on the standard 180.
cupra r has only got the 323 brembo's... id hazard the cupra would be the same as the octavia with 312's
S3's also have 312's sure some passat 4motions have them too... theyre are loads... when i bought my ferrodo 312 pads they're was a huge list of vag cars on the back they fitted
Audi TT
Audi S3
Octavia vRS
4Mo Golf/Bora (MK4)
V5 Golf/Bora (MK4)
V5 New Beetle
Leon Cupra
Audi TT
Audi S3
Octavia vRS
4Mo Golf/Bora (MK4)
V5 Golf/Bora (MK4)
V5 New Beetle
Leon Cupra
Good info - cheers mate!
I thought the V5 stuff had it. Hopefully that will be a way of sourcing a cheap set of calipers as nobody want's anything from the V5 cars!! lol.
weren't the brembo's a cost option on the cupra R at one point?
Hi , does this brake upgrade fit inside the stanard 16 inch wheels
cant afford both at the moment , prefer to stop than look pretty !
looking at the website mentioned above they seem to squeeze in ok.
Yes they fit in, and look mashoosive
?iid=yfyjdj&outx=600&quality=70
