poor interiors
the longer i have my 54 reg octy vrs the more im convinced the interior is not of a high standard. i say this because almost weekly a new squeak or rattle starts fro the doors or the dash or the rear parcel shelves. i was wondering whether anyone else has the same experience and if they did how did they fix it.
I have a 2001 TDi estate, and the only rattle I get is from my gear lever, when in 3rd. 143k on the clock and counting....
the main rattles that bug the **** out of me are the rattles from inside the front doors which sound like things are loose in there but the windows and locks stillwork fine.
I have a 1999 TDi - no squeaks, rattles or vibrations.
A mate kept getting rattles. In his case it turned out to be an engine mount.
Metallic sound rattle? Could be a window guide? Does it only happen when the window is in the upper most position?
Edited by mbames
spelling correction
My 01 vRS is pretty rattle free, just the glovebox door catch rattles a little when it's cold.
Most rattles and squeaks are introduced to a car when interior trim isn't put back properly after a repair. Has any work been done to the inside of the car in the past ?
same here mines just started doing it :(
I get slight metallic noises from inside the front doors when I'm blazing the tunes, but then I do have 140 Genesis watts per side going into 6.5 inchs of DLS reference mid. So a little additional vibration is to be expected, no matter how well deadened the car is ;)
Apart from that she's sweet as a nut. Best car I've ever had!
a repair to the elec windows was done and the rattle does happen when the window is in the upper most position. the rattles stop when i push in the door card lightly. i have a feeling something has come loose inside the door and will ask at the next service for them to inspect it(as long as they don't charge a fortune). but thanks for your replys.
2002 TDi; one intermittent squeak from the LH B-post trim, and after nearly 3 years on the roads up here that's quite a feat!
I have seen a few loose window regulators that cause rattles.
99 Octavia SLXi, rattling from roof, or somewhere behind me, god knows where, but its amazingly annoying.
Jon
Mine rattles/squeaks a fair bit from the back.
After closing the boot it rattles for 15 miles or so then settles down again :S
It has a few others but its the one from the back that bugs me :(
