How to fit A Seat Strut Brace on the Fabia (discussion)
AFAIK the bolts hold the top of the strut - i.e. the shock absorber - in the turret. No it won't drop out unless you have the car jacked up at the time (don't jack it up for this job :D )
  • Replies 142
  • Views 12.4k
for me, 25Nm is "as hard as I can more or less tighten them with a piddly little 12" wrench" :rofl: And a turret hasn't fallen out yet. :rolleyes:
If I can remember right, One Newton Metre is roughly the turning force exerted by an Apple (Bramley is OK) at 1 metre :) So, if you go to Tescos and buy 25 apples, and hang them on a 1 metre extension bar, you should have approximately 25Nm of torque exerted on the pivot point.
(Why did I write this?)
no idea but im gonna return my torque wrench as that way is much healthier lol
If I can remember right' date=' One Newton Metre is roughly the turning force exerted by an Apple (Bramley is OK) at 1 metre :) So, if you go to Tescos and buy 25 apples, and hang them on a 1 metre extension bar, you should have approximately 25Nm of torque exerted on the pivot point.
(Why did I write this?)[/quote']
:rofl::rofl::rofl:
And dont worry nothing would fall out even if the car was in the air, you only take out two of the three securing bolts.
Ahmen to that :D
Unless you buy a Forge Motorsport one ;)
Yes if your apple weighs about 102 grams. A Newton is the force exerted by 1kg of mass so you divide weight by the acceleration due to gravity =9.81m/s/s to get mass. All this means that you multiply lbft by about 1.36 to get Nm...
e.g. 65lbft (wheel nut torque) = 88Nm (ask a tyre fitter, he'll tell you he uses 90).
well i just ordered mine :D its here tuesday i just hope this 49.98 is worth it :D
well i just ordered mine :D its here tuesday i just hope this 49.98 is worth it[/b'] :D
Not to sure if it is but it looks good :D
Im trying to fit my S B now and having problems lining the holes up can anybody help asap?
The holes lined stright up with mine no problems.. It is a Seat Sport one isn't it ?
Fitted mine Saturday. Took 20 mins, after buying a decent socket set!
It does seem to improve handling. Keeps the front end a lot tighter. And yes all the details for cost are spot on. I got mine from Seat in Watford for
Hey no worries just glad to help out :thumbup:
Funnily enough I've got my 20k service to do next week and was going to do the same, including a pollen filter change.
Ross, with so many people fitting new suspension, a really useful 'How To' would be removal and replacement of springs and dampers, especially the fronts!
I was looking at doing this (Not on my own car but a donor car) for free but I understand apart from spring compressors which I have there is another special tool that you need to buy. Ross is that the case ?
I have lowered lots of Clio's and have even created a how to on the cliosport website, but I have been told it is different on Fabia's.
I would also like to know the best way of getting the dampers out the hubs....with out using a ****ing big hammer. lol
Great ideea, great article!! :thumbup:
The only thing that is missing is the conclusion. Don't get me wrong, the conclusions have to come from those who have already a bar on, not just from one person ( the writer ).
Beside the good looks, how much will it improve the handling? Is it a serious improvement or just placebo? If better cornering is the issue, can the SB help or one should start modifying the suspension ( springs, stabilizer etc ) first and then the SB?
It's only just occurred to me to ask (mainly cos I don't own a Furby), but WHERE is the "how to"? I've just noticed this thread is just a discussion about something but doesn't contain a pointer to that something.
Is anybody else confused too? :confused:
I did ask Collin about this, I did look in the other ;) forum we have access to but it wasn't in there either ?
Also the how to fit an internal tray one has gone as well.
Answers on a postcard to the usual address.. :D
Weird I can't see that forum if I trace it back each level !!
There again I have different permissions now so maybe I can't see it.
## edit ##
Just spoke to Collin about it and I now understand how to view these :thumbup:
## edit ##
numb nutz
numb nutz
:finger:
I have a few different sections to you which accounts for the mistake, Flap cap whippet man :P
