Fabia vRS 56 plate with 37k service due
Hi all
I've done a search but can't find what I am looking for. The car is a 56 plate Fabia vRS and is coming up to its 37k service (40k?). Car was last serviced at 27k.
How much would I be looking at for a 40k service at a main dealer and what is involved?
Anyone had one done recently?
6 months younger than my car... mine is due a cambelt change (only done 32k) in May 2010 and full service so guessing yours needs similar?
Be changing of oil/filters/brake fluid and checking of usual brake discs/pads etc
Expect it to be circa £200 + and factor another £200 or more for cambelt if its due, every 4 years or 60k now.
£200 for a cambelt from a dealer? the parts alone are nearly £150 from skoda !
I thought the belt was done at 60K???
4 year / 60k
cambelt kits are less than £100, what else are you fitting ? :confused:
You could always ask a dealer.
I thought the cambelt was something stupid like £12 or something? It's only a belt innit? I thought the cost involved was to do with the suffering caused by fitting the thing. Either way, mine ain't due till May 2011... :D
Hi all
i asked a skoda dealer in west london, Isleworth bout 3 months ago
they said
40k service = £300
cambelt = £450
i was like :eek: wtf
in the end amd in surrey done the 40k service for £253 (i thought it was expensive, but great service) and the cambelt believe it or not, i got for £240 :thumbup: from a mate of a mate, he works 4 audi. he said that the cambelt parts and water pump came to bout £170
hope that helps
mines a 55 with 49000 on the clock by the way
if you're doing the belt, you also need to do the tensioner/rollers etc. Not sure where you got £12 from though :rofl: If only!
Skoda garage did mine for about £300 with water pump which I thought was okay.
Cambelt kit, water pump and 2 bottles of g12 plus plus, the correct parts:thumbup:
but if the OP only wants a cambelt done, the kit is about £100 ? and lets face it , the engine is hardly likely to need a water pump at so low a mileage, yes i know the impellor can fail, but usually at higher mileages in my experience, so maybe a pump change at the second cambelt replacement, somewhere near 80k ?
Yes the pump is optional i dont force people to have it changed lol, but at the same time i ve seen them fail at 20k:eek:, i ve even had one come in on pdi with a failed pump and blown head gasket
on Fabias or another VAG product ?
