now with added zing
4 bar upgrade on the octy vrs is a good-un added with the hurricane that i have put back on :rofl:
car is running like a train.
off to the www.seatcupra.net RR day at jbs tomorow will post up my plot .hope its worth posting :cool:
off to the www.seatcupra.net RR day at jbs tomorow wi;; post up my plot .hope its worth posting :cool:
Sounds great, good luck Jason and make sure your cars had a good chance to properly cool down after the drive there before you put it on the rollers, to avoid heatsoak problems... but then, you don't need me to tell you that :)
should be a good day out ,rollers packed up on the last one this is a revisited sesh.
need some proper cold air piping,bit bodged at the mo ,using stnd hole in wing
well i am quite happy with that.
221.9 BHP
257.1 torque(would that be lbs ft ?)
max rpm 6170
max speed 124.3
power tailed off a bit at the top end between 5500 and 6000 rpm
Good to meet you Jason and a good result :thumbup:
you to rich.
give us yer grille surround? :thumbup:
nice straight curves on the plot, shame the torque curved off so quickly... maybe thats the way its setup on the car (??)
the torque would have been measured in lbs per ft though, a nm figure would be alot higher than that.
what others mods are on the car? and what difference did the 4bar conversion make to the last RR results?
  • Administrators
I'd suggest blanking your registration details ;)
You can delete that attachment and upload a new one.
Not bad, although the plot seems a bit uneven towards the end.
i think the hurricane may be the cause of the lack of top end.its only rated for "around "200 bhp,i have a panel filter on the way , so gonna try that with a cold air feed,dynoing at stealth next month so will get a comparison.
editing now colin ;)
idynoing at stealth next month so will get a comparison.
this dyno running at stealth, is it another group thing or you going alone ?
wouldnt mind getting mine run to see whats things are doing.
theres a multi forum one by a guy from cupranet,theres about 40 unconfirmed,no way stealth will be able to run them all,i have pulled out.
not sure how much they would charge you to just pop down on yer own for a run.
theres a polo one soon iirc,advertised on here???or maybe cupranet
