Cant turn them off
Are the DRLs in the fog ligths or in the main lights? My 09 Elegance has corner lights and when I turn DRLs on the maing lights turn on (0 and auto setting) even if it is bright sunny day. If i turn DRLs off then no lights come on.
I got my car used so maybe the previous owner did some some vagcom work to change DRL behaviour?
My DRL's are the outer bulb in the fogs a 2010 Elegance my car has 3 bulbs in fog lads
My MY11 Superb Elegance build week 44 has only two bulbs in the fog lamps. Outer DRL inner Fog. Vehicle has working DRL Fog and Cornering.
Seems that -09 Superbs did not have DRLs... So that's why my car does not have those.
There's only Two Bulbs in my 2010! - And i've just been out to try it! - it looks like there are 3, but it's a reflection of the bulb...
Also i've had a read of the manual, it also shows only two Bulbs in the Fogs... One outer, Standard filament (DRL) one inner Halogen (FOG / Corner)
Al.
Al.
I should have mentioned this. Depending on the angle you can see what appears to be two bulbs in the outer position (DRLL, again it can also appear to have two inner bulbs (FOG/Corner).
My first MkII 58 reg had DRL's, they were in the headlamp unit, and the headlamp bulbs worked at 90% power, rear lights also on, the newer MkII's just have the DRL's in the fog lamps working.
