Some minor changes over the past few weeks
Hi guys, thought id splash a bit of cash on the vrs...and since we have more daylight i have been cracking on with a few bits and bobs
Some mods might be "marmite" but i ove it and thats all i care about ;)
firstly i changed my Wishbones over with ball joints...made a world of difference :D
I then used the Flyeyeskit i read about on this forum
before
and i did the fronts aswell
before
one done
up close
with HIDS on
Both,, going for the Murked out look hehe
Also waxed it with collinite
I then started work on my CarPC
Edited by vRShafz
for those interested in the spec
Intel atom d945gclf2 mini itx mobo
m2-atx
160gb hd
2gb DDR2 Ram
Windows 7 64bit
centrafuse 2 front end
Voom case
Double Din liliput touch screen (bezel need some work doing to it)
gps receiver,camera, wireless etc
oh an I can use 3g net by tethering it of my iPhone :)
Today i managed to get it all crammed in the case
The case acts like a big heatsink
and a Hovis shot for people :D
and a Heinz beans one too to show the height of the case
Then i moved on to stripping the Dash down. Nice double Din space
I then modified the Double Din frame to fit inside the space. That was as far i got on that front. i need to do some filling and sanding so i left that for today
i then moved onto giving the PC a Home in the boot. I opted to use the spare wheel well foam as its out of site + the foam will act as a shock absorber
Foam Before
and after some cutting the pc fits in perfectly
i did have to trim some more to accommodate the ports
Since i want to control volume through my standard headunit, i had to relocate it.This will be going into theglove box
After some cuts/bruises/swearing..i managed to get the wiring loom free so its enough to plug into the headunit in the glovebox
This will be securely fastened once i get time to finish it
car as iv left it for today
i love the fact we have more daylight :D
roll on modding days!
im hoping to have this all in fairly soon!
comments welcome
*update*
done a few more bits and bobs
All in the boot with wiring
and then carpet hides everything
headunit in the glovebox - this is purely for speaker output
and the big switch on was this evening and im pleased to say it went without a hitch :D
the screen will now be smoothed in so it sits flush with everything else
Only fitted it for now for testing purposes
at night
Pictures of my car can be found here http://briskoda.net/forums/topic/144462-pics-of-the-black-beauty-mk1-octy/page__p__1808171__fromsearch__1entry1808171
But iv now got the Whole care tinted
Edited by vRShafz
Mate that is cosmic (my word of the day)
I take my hat off to you guys, ive seen someone do this before on a mk4 golf.
Looks brilliant
Wow that is awesome!
Have you thought about getting VAG-Com running on it, then you can leave it plugged into the OBD port all the time too?
Looks brilliant
thanks bud just something a little different
Just waiting on a chap to get back to me so i can get the screen properly flushed into the console for that OE look
just working on getting my In-Car camera setup
How much has that set you back by? I quite fancy a PC in the car, and would be a definite bonus to run vag-com on it. As I have an older serial cable it looks like that machine might do the trick..... Where have you mounted your PSU, I assume that is separate?
what about radio features? Is that provided by the original HU?
Looking good though :-)
Hi mate, the PSU is a m2-ATX which is a DC-DC powersupply made for automotive use
good place for bits is linitx.com or digital-car forums for used bits/advice
its only a small circuit board PSU
My PSU is mounted on the motherboard plate in my case (right hand side of the picture with 3 wires coming out of it)
only needs 3 wires to power it
1-Perma live
2-Switched Live
3-Earth
i bought everything used or had lying around so saved a fair chunk, i guess iv spent around £250 inc screen
I dont listen to the Radio, but i can turn the PC off and use the headunit as normal or a USB FM transmitter can be bought for the PC
(no idea how well it works)
hope that helps
Edited by vRShafz
sorry to bore you guys :giggle:
CAR PC?!!1 OMG COOOOL :) :) :thumbup:
if a little pointless ;)
i can safely say this is pretty cool, looks like you are good with the old wiring then
I am Impressed with that matey :thumbup:
excellent project
Wow that is awesome!Have you thought about getting VAG-Com running on it, then you can leave it plugged into the OBD port all the time too?
Thanks Mate, fitted a camera in the front grill over the weekend which records automatically when the pc is running and configured to delete recording more then 3 days old. will post up a sample when i get time
I have got one of them cheap ebay VAGCOM leads which i use to check for error codes. im running windows 7 64bit ATM and VAGCOM is a pain to get it to work with that. ( i believe there is a new version out that is compatible with win7 but not tried it yet)
I may revert back to XP but il see how it goes with this
Also fitted my wireless adaptor so i can easily download songs to the car from my home network
CAR PC?!!1 OMG COOOOL :) :) :thumbup: if a little pointless ;)
does more or less the same a £600-£700 unit does at less then half of the price + the upgrading options on this is larger then a normal double din unit
here is the system in my old car
also sending my screen off this weekend to get it smoother professional. Want to have the screen sitting flush with the console so it looks as OE as possible
great pics love the lights.did u go with the dark or black tint when you ordered it
darkest black tint ;)
defo looks the muts nuts.very nice
I`m liking that, proper good work! This is the first time I`ve seen the Fly Eyes kit, looks superb, question though, did you order 2 kits to do all, headlights/indicators/rear lights? Also, have you fitted the darker versions to yours I`m guessing?
i ordered the varient 1 shade of black
http://www.flyeyeskit.co.uk/order.php?col=black
But i ordered the £20 roll of ebay where you get more (none listed at the moment though)
Love the onboard pc install,top job :)
and i ordered my light tint from lamin x website which is pretty good and it's great stuff too,i got the lightest tint though as my headlights are poor as they were so didn't go too dark,need to buy some hids again i think lol
Edited by dsmithmobile
how easy is the lamin x stuff to apply? especially around the curves of the lights
Apparently it goes around curves pretty well but i didn't mess around to be honest,i just applied it to the face and trimmed around as i thought it would be easier but once it's warmed with a hairdryer its pretty flexible stuff :)
did a few bits and bobs today
Fitted a rear camera into the Skoda badge
(still needs tidying up but you get the idea)
Also fitted a front on behind the mesh, so its hidden
Removed Badge - Nasty marks underneath it
Edited by vRShafz
