EGR delete - ASZ
how do you know which engine is which,is it stamped blt or asz anywhere. ta
Check under the carpet in your boot, there should be a big sticker on the floor and it will say amongst other things the engine type code
tells you in inside page of the vrs handbook...
I ran a 57mm egr delete on my old vrs asz engine for 40k no problems
Now running a larger 62mm egr delete for maximum flow :8 on an asz too
The only gain is no soot build up in the inlet manifold, and slightly improved throttle response under light loads only. The negatives are slight reduction in MPG, and increased combustion temperatures at sustained cruise speeds, with engine under light load. There is some debate as to wether that would result in valve seat damage, if car driven lightly most of the time.
The car will also stick out a lot more NOX which is extremely toxic.
although NOX is not tested for during an mot in the uk!
Good old Blighty in the vanguard once again!
I might just go along with it. Chances are it wont be like this for too long anyway as i'm thinking I want a petrol turbo car in the near future...
traitor..:finger:
traitor..:finger:
Haha. I want more power without having to spend thousands on Hybrid in the vRS lol
What happens if I leave the second vacum pipe open btw?
are you disconnecting the pipe from the ufo and asking what if you disconnect the anti shudder pipe and leave open?
leave the anti shudder pipe connected.
Noo, i've got an EGR delete pipe on there now. But before I start her up I want to know whether I should block the lower hose that was on the EGR or vent it to atmosphere (the ASV hose)
block both..
Okay :)
you'll be back ! you will miss the torque, reliability and fuel economy of a diesel !
believe me!
ive built 500 bhp cosworth engines in mk1 escorts
ITB'd 2.0 litre williams clios
took my peugeot 205 to way over 200 bhp weighing less than 750 kilos !
and nothing puts a smile on my face like a punch in the face from the torque a diesel gives you
  • 7 years later...
On 7/7/2010 at 16:11, f0xy said:
why is it that this comes up so much !! only yesterday there was a couple of topics very simular to this !
as said..
leave the egr in place and disconnect the top rubber pipe and blank off
then vent cc to atmosphere
the search will bring up everything you need to know on this topic!!
by the looks of things it has come up many many times
regards
austin
Sorry to drag this post back to the present day, but could someone enlighten me on the above WRT "vent cc to atmosphere"?
Crank case breather. Search for the elephant hose mod.
Ok many thanks!
