Traction control light coming on by itself?
Once ive been driving for say 10 mins or so the traction control light comes on (the exclamation mark in a circle) and i cant turn it off via the button.
It doesnt appear to affect the traction at all... but just wondering if this is normal?
Also, does the light on mean traction controll is off?
Craig.
Craig.
i would get the fault codes read with VAGCOM etc
could be a wiring / wheel sensor problem or possible the switch to turn it off is faulty
if the light is on, i believe traction control is disabled due to a fault or it has been switched off with the switch by the air vents,
if traction control is working, when traction is lost the light flashes and from my experience engine power is often decreased temporary to regain traction, then the light goes out once everything is under control again
If i turn the engine off then back off again the light goes off and then comes on again 10 minutes later...
Yep, fault code scan time. I'd say ABS sensor fault is a likely candidate, as it will take some time for the ABS controller to suss something's up...
My guess would be that there is something wrong with the abs-sensor.
TCS uses abs-sensors data to determine whether wheel is spinning or not.
Is thi something worrying / expensive?
I have MOT next month... will they fail it?
My money is on the "LOAD SIGNAL WIRE" in the engine bay - it gives this fault when it breaks - 10 minute fix with a soldering iron
Please, correct me if I'm wrong, but isn't the symbol you describe one that shows a fault with the braking system, either low fluid or the handbrake is on?
Is what we though, but then after looking properly its not.
The one i have coming up is an exclamation mark in a triangle which is in like a circle with arrows either end! If you understand me :D
To be absolutely sure, we're talking bottom-left, not bottom-right:
hotlink fail :(
Craig.
Hold on thst light is to tell me my handbrake is on...... my tracation control one is the car with the squiggly lines behind it, like some dude having some fun on some ice...........
Hmm. When i ever i press the TSR button or w,e it is it turns on and off the button i said...
Found an image (obviously not my fabia...)
The orange one between the dials?
Can we confirm - which light are you talking about?
Is that the Fabia II manual? The ASR light on the Fabia I looks different:
still hotlink fail :mad:
(I know that's a BMW, but the symbols are the same...)
Its none of those.
But this: (obviously not from a fabia but its the same light)
The orange one between the dials.
Im now thinking its something to do with the brakes. I know my disks are worn with a slight lip... but i dont see why the light comes on when i push the ASR button...
Edited by Craig Lovelock
Yep. Traction control. So either get a fault code scan, or get an auto-electrician on the case... :)
Ah okay so that defo is the traction control signal lol. Seems to be different types... :'(
Where can i get the fault codes read?
Nope, Fabia I manual.
The lights in that manual all match up perfectly with the lights in my 56 plate vRS? :wonder:
Might be facelift?
Mines a 54 plate.
Must have changed it at some point between 54 and 56, then. Everything else tallies, I think...
Probably.
Well, ive emailed a person with the software from around my area.
Thanks for all the help and information.
We had the same thing as the OP has described on his car happen on our Beetle. It turned out to be the ABS Sensor, luckily car was on warranty.
Lewwy
yes it changed with the fabia facelift....
around 54/05
my 04 plate had a exclamation mark and my 05 had a skidding car
my golf does it now and again
only way to tell is vcds check
saying that mines hasn't reappeared since i fitted a new battery
or have a few other faults
:o
