Fabia refurb underway, project 1.8T
The mounting looks like this
They are all now painted and the cover has had some trim fitted to it to make the bottom edge nice and neat.
  • Replies 429
  • Views 80.6k
  • A little update All bolted in and lines up
  • Can't get the engine up to the car? Then bring the car down to the engine. And back up with the car.
  • After a time resting the project sprung back into action today. The car sat in my new unit Shortly after things started to happen and then The unit is filling up with spare bits Now hav
The engine bay will look amazing when it's done :)
Hopefully, it will be different that's for sure.
Definitely I cant wait to see the engine fitted
U going all the way with the bay then ross?
Id love to do it 2 mine but it would end up off the road for months lol..
Not smoothed like that, more tidy. Plus that still has the bulkhead lol
Sneaky peak :)
At long last the engine and car are in the same location lol
Ooh looks brilliant :)
Looking good.
How much excess weight will you be able to remove from the Fabia, with the bulkhead etc... ?
Weight won't be to much really its only a thin bit of tin.
n/s chassis leg is pretty much stripped down now with all the seam sealer removed.
I didn't know if you were going to be removing anything else to make it a bit brisker.
Looks good Ross
I can't give away everything :)
Coming along nicely.................................so excess bits of metal removed............no "Elegance spec" upgrades..................
HHHHHmmmmmmmmm...................going for power/weight ratio............ ;)
......so driver has to wear just a set of Speedos???????......................or a Mankini??????.................... :rofl:
Any latest news on this Tech1e??
How does the car work? Lol
Just read this from start to finish great work, will be keeping an eye on this thread :)
you not running power steering or is it electric on the fabia like this...
From previous posts, it would appear its the electric pump :)
Coming along nicely
Coming along nicely
it's hard to see how that engine is attached to the body?? is it bolted to the subframe like on a mk3 golf?
Standard Ibiza arangement ont he drivers side, standard dogbone mounting to subframe and a custom mounting on gearbox side. The standard mounting did fit I just didnt like the look of it so now its bolted under the chassis leg instead.
