Money no object
Just as a theoretical question......if you had a bottomless pit of money to spend on rebuilding your vRS what would you do.....I know that "buy a Ferrari" would be a common answer. I have years of experience modifying petrol cars, but non at all on diesels. In my 36 years on this planet the car I purchased a week or so ago is my first oil burner...do they respond well to high lift cams for instance....big turbos...bigger injectors etc etc
If you had a million to spend on your Fabia...what would you do?
PD160 intake
RARB
312mms.
Then spend the rest on coke and strippers!
Engine tuning wise:
. Tubular exhaust manifold
. GTB2265VK hybrid turbo
. 3"Turbo back exhaust, no cat, silent backbox
. Custom intercooler, same dimensions a Seat, but bar and plate.
. Hardpipes
. 4 bar map
. Bosio injectors nozzles
. Diblas cam
. Jabbasport headwork
. Bigger valves
. PD 160 intake
. Green air filter
. Remapped to suit.
Then water meth injection to keet EGT's low, Spa Oil temp/Oil pressure gauge and boost pressure/EGT gauge.
R32 3.2V6 engine, 4 wheel drive + all the trimmings... breaks etc.
Oh and then add an S2000 body kit :rofl:
Give it to Ben @ Shark,tell him i want 300bhp,enough torque to spin the world and make it handle like an Ariel Atom :giggle:
Oh,and with the change i'd buy myself a Koenigsegg :thumbup:
Wrc body kit, extend track, rose jointed, fancy diff, gt2260, fancy seats and handed over to someone to sort the suspension.
sell it, by a mk2 escort and spend the rest on it :giggle:
turn it into a excat replica of a WRC Fabia.
turn it into a fire spitting rallycross car up to 500 bhp and 4wd :)
buy the wrc car.. simple
I'd try and get someone to fit the five-cylinder turbo'd 2.5-litre TFSI 335bhp engine from the TT RS, and the quattro system to go with it :)
Marc
I wouldn't touch the vRS - I would go and buy an old S4 Audi (2.7 bi-turbo), a 1.4 fabia, and then combine the two with some bonkers mods to the S4 engine & drivetrain. Aim to make a 4wd Fabia somewhere in the realms of 600 to 700bhp. :) If I won a significant amount on the lottery I would be doing this like a shot. The two cars would be cheap to buy, but the modding wouldn't for sure. :D
Yup, as has been said before, Ben @ Shark Performance would be the first person I'd call, but not about the vRS. First thing I'd have would be a big big power Lupo, badged up as a 1.0L, maybe with steelies and hub caps too :giggle:
Send it off for a 2265VK hybrid turbo conversion, probably looking at over £10k to get the full potential from the turbo, reliably & to sort everything else out to suit over 300hp.
Spend £1.31 on a litre of unleaded, set the Fabia on fire, then spend the rest on commissioning a Lamborghini Estoque.
I shouldn't but I lol'd. :D
I'd rip out the back seats and replace them with a mid mounted hayabusa engine driving the rear wheels, then replace the engine in the front with another hayabusa engine driving the front wheels, sure would be expensive but I know it would also be a box of frogs to drive!!! :p
Oh and of course a roll cage to stiffen the whole thing up!
a Smart car with a one engine conversion!!!
Dean
Edited by deanyboy1985
Weld the back doors up and graft some ibiza doors on it?
Then do away with the diseasal :)
Id keep it a it is [maybe add a few extra torques] and use it economically for work emoticon-0110-tongueout.gif.... oh wait a minute i wouldn't be going to work if i was loaded emoticon-0145-shake.gif..... emoticon-0102-bigsmile.gif
Make a 4x4 version. :thumbup:
I would be soooo tempted to turn mine into a full on unlimate spec rally car with the full on wide body kit..but obvious!!!!.....How about a highly tunned 1.4TSI engine out of the current Fabia...leave the bodywork as normal (still sorted eg stone chips etc) and sort the suspension & brakes etc to match the engine....Street sleeper style!!!!! B)
I`m liking the rally options :thumbup: .....I think it would definitely be high on my list of things to do...short of buying a real WRC Fabia....although there is a long list of rally cars I`d buy first starting with a Lanica 037
The WRC bodykit for the Fabia looks very cool if not a bit expensive...also a lamp pod to finish it off nicely :rofl:
not sure what I`d do enginewise...cams, a turbo, custom exhaust and a remap would probably do to start with....not sure about a 4wd conversion...already have a 4wd car and I enjoy the handling of a FWD car, they are alot of fun and you cant get yourself into as much trouble as you can with 4WD
double post :S
Edited by Insanity-74
