MFD speed display
Hi,
Just wondering if there is any way of switching off the annoying small second speed in kmph on the mfd?
It states you can using the left hand button in the instrument cluster to turn it off but that button only changes the time ?
Any ideas ?
Not on the UK models. EU law dictates that all cars must be able to display km/h... The display is switchable in other countries between km/h and mph and in theory you can tell the car (using VCDS) it's in a different country and then you'd be able to remove it...
Hi,
Any ideas ?
Just had mine changed to mph much better, it now shows large digital mph display and the temp. where the kmph. was ,can still change it to kmph with the multi dot. A garage called P.S.I. in Newcastle under Lyme did it for £24 all in . Brill.
Ok cheers , I'll just put up with it and pretend it is in mph and that I'm going super quick !
Hello, sounds good , I'm in the proper newcastle though so it's a bit far !
Edited by dickyd
Im looking to pick up a mk2 vrs soon enough...
Also i have VCDS and im in newcastle, if i manage this i will make sure to PM you.
anyone in north wales with this vcds thingy
Mr Gorebrush has it - see vid of the "Australia mod" on you tube (search for Gorebrush).
He's in South Wales though.
i would rather have my oil temp down there instead of the speed ...
done this on my polo an i never use it id rather look at the journey time emoticon-0140-rofl.gif
