I need help desperately
The engine management light has been on in my car (Octavia vRS) for a while, i had it checked out and there was a short to earth problem. It was rectified and i was told to take it back in a month to have the di-ag ran again to see if any more faults had occured. Low and behold the light came back on not long after. However, now the car is vibrating when i drive it there is no power and the engine management light has started flashing. Needless to say i have stopped driving it. I am aware that there could be many cause, but does any one have any rough ideas what it might be?
Should i drive it to the local Skoda Dealer or have it picked up?
Any help would be appreciated. :confused:
Could be quite a few things (some fairly minor to fix, some not). Personally, I'd get it recovered to a dealer - if you're still within the 3 years Skoda AA Assist thing, it shouldn't be a problem at all...
Rob.
The most likely cause is that one or more coil packs have failed. Use the Skoda-provided AA breakdown cover and it should be fixed at the roadside.
Coil pack?
Coil pack?
You read my mind. :)
sorry if i infringed your civil liberties.... i was nto trying to get the thread locked.
:o
MAF - have you got a flashing traction control light as well? Get it relayed to a dealer by the AA.
No, traction control light is off. Does sound like it is missing at low revs though
Hello Buddy,
As the previous guys have said sounds like a coil pack to me.
Seems to be a pretty common thing on the occys
Hope it gets well soon. :thumbup:
Flashing ecl is normally an indication of a misfiring engine ,with a steady light as an indication of some other fault... therefore I'll be with the group that says "coilpack"
Yup - like the others have said, it sounds like a coil pack. Is there any hint of a "rotten egg" smell from the exhaust? That would (I think) clinch it.
I notice from your profile that you're in Weston-Super-Mare; I'm just the other side of the Bristol Channel in Newport. If we can work out the logistics of getting it from A to B (difficult for me this weekend) I have a spare in the boot which you are welcome to borrow, to get you back on the road.
I had the exact same thing. Flashing engine light, no power, and the smell of rotten eggs. Its a coil pack.
Although, I think the rotten eggs may be the wiffy old gimmer we used to live next door to! :rofl:
But but but what's a coil pack?????
SR
It's used to deliver a spark to the cylinder, IIRC.
As an aside, they're not used on the 1.6... :)
Rob.
SR
basically its the plug lead with a coil on top,one on each cylinder ;)
