Random door locking and light
Well I think I have the window connector thing problem lol. Ok my door open warning light is on, the interior light does not come on opening any of the doors. Sometimes using the fob locking the car the drivers door pin won't go down and sometimes it's the drivers rear passenger door pin that won't go down
Very random, anyone has the same ?
Water ingress into the loom in the drivers door connector block probably. Or maybe a microswitch/dry joint failure in the lock on the drivers door.
Do all the controls from the drivers door for windows / locks / etc work properly?
When locked does the LED flash?
When the door is opened does the door puddle light come on?
i had a smilair problem my interior light wouldn't work nor would the dash say the door was open or the led in the door flash i changed the drivers door lock and all functions are now working fine but the led still wont flash where is this control module in the door? are they cheap and are they plug and play or ned to be programmed
All the controls work fine and the puddle lIght comes on, the led flashes too ?
I had similar problem but only the drivers door, a trip to skoda yesterday and £177 lighter its all fixed now
