Water leak fabia vrs
I have a water leak on my car and just wondered if anybody has had any simalar problems if so what where they ive changed the 2 main things the header tank and the pipe to the block but its stil there any help would b nice thanx
I have a 54 plate fabia vrs and its looseing about 2-3 litres of water in the space of about 5 miles if that has any body ever had a problem like this if so can u give me an idication of what it could be im thinking its a leak and not the head gasket as it wudnt loose it all that fast
have you checked the radiator hoses, coolant tank hoses etc you got to be careful and take it to a garage asap or you will mess up the headgasket get it checked out by a mechanic ASAP
Ive changed the header tank and also 1 hose that was split il look at it monday when i go back 2 work just wondered if anybody had any simalar problems so i could look
In that sorta area
Im goim 2 look thru the paper work see what its had done in the past
Suspect holed radiator.
Im hopeimg thats all it is lol
Ive had alook under the car with the sump tray of and i just cant find any antifreze driping anywer under pressure but its loosein about 3 litres every 5 miles if that has anybody had any problems like it aoart from head gasket as it wouldnt loose dat much this quickly if it was that im finkining mayb a water pipe near turbo n then its just vapourisimg the water thats leaking any input would be great thanx
could be a split hose or faulty rad maybe?
I guess your car is a Diesel VRS as if it were a Petrol VRS you would have it at the dealers being sorted under warranty.
Edited by seagull
Yes mate its the diesel
You could not vaporise 3 litres in 5 miles.
So you say you've been under the car with the engine running and no drips anywhere? And you've taken the engine tray off? I still suspect the water pump or a major leak somewhere.
Yes ive let it warm up n presurise n ther is no leaks from anywer that i can physicaly see myself no drips on drive way from overnite parking and its still useing all the water in the header bottle going to investigate further 2 morro as im
Of work and can use the ramp lol
It's not my old fabia is it ma06 bko?
Nah its a 54 plate
If your losing 3 litres every 5 miles, then the leak should be noticeable while stationary, even with the sump tray in place. Try running the engine and having a good look around underneath with a torch and through the engine bay and down onto the tray etc, if you don't have any joy then you can obviously remove the sump tray to get a better look...
Could be leaking from any pipes in the system (follow them around from the expansion tank), water pump or from the radiator, or of course it could be a head gasket failure, especially if you aren't getting a visible leak...
Edited by SkodaFabiaOwner
Garage investigation, pressure test water system to pin-point fault, and save yourself some hassle.emoticon-0148-yes.gif
The radiator fan switch on the left hand side of radiator, half way down could be the problem. They often leak on Fabias & Polos. If this is the cause suggest new switch, sealing ring and PTFE tape should fix it. A deep socket is the best way to remove due to space limitations for ring/open ended spanners.
Cost about £16 for switch - check for sealing ring inside packet before leaving the store.
Yes im takeing it to my mate later eho is a vw specilist so i hope its just sumit stupid lol it wont b head gasket im hopeing as if it was the the engine would lock up with that much water in the bores it would hydrolic its self n i dont think its water pump has the water stil blow warm air so the water is stil pumping around the system
Please do not post multiple threads on the same subject all over the forum, simply update one of them. it helps in the future if someone else has the same problem.
I have merged several threads into this single one, so the replies may seem a little strange, so lets please keep it like this.
has this been solved ????
Ye its it bits at the moment
