Not your normal HID question......
Seeing as Octy drivers are far more observant than our 148mph License-Losing Fabia bretherin.....
Has anyone seen proper, legal, OEM, Factory-Fitted, HIDs in reflectors? So far all I've seen is them used in projectors (like the Octy). Would it be safe to assume that all HIDs are in projectors?
I also found a way to simply describe the difference between halogen OEM and HID retrofit........
If you get a Maglite style torch, switch it on and point it at the wall, you'll get a proper full-on beam pattern as the light-source relates to the reflector as an optimum. (This is like a halogen correctly installed)
As you unscrew the lens you'll notice the beam pattern will deteriorate. This is because the light-source is no longer in an optimum position in relation to the reflector. The result is light being scattered into all the wrong places and dark patches appearing. (Just like a retro-fit HID) This also happens when a halogen it fitted wrongly, usually giving the impresson of 1 light on dip and the other on main-beam.
Obviously this relates more to reflector technology than projector technology, but then most retro-fit HIDs are usually done to reflectors.
Edited by RainbowFore
Oi... don't tar us all with the same brush :p
Waveydavey's Lexus has OEM xenons in reflectors. There are little cups around the bottom of the bulbs to stop scatter.
The OEM Bi-Xenons fitted to my Audi A8 are in standard reflector headlamps and not Projectors. At first I didnt realist they were Xenon, but the members of another forum have confirmed that they are and that they are also very expensive.
You need to have them re-sett by a mot center ,then no light scatter :yes:
Honda Civics also come with OEM Xenons in reflectors.
Was just about to chip in with the Civic answer, then refreshed and saw Mark's answer! :)
Yes, Civic shape about to be replaced. I actually went to try one as I was considering a purchase at one point. The EX spec level has them as std. I have to say though, because they're not fired through a projector I found the light output and quality wasn't as good as an OEM projector xenon setup.
Renault Lagunas had OEM xenon in reflectors too. As do/did some Volvo's
You can get Anti Dazzle kits for reflector type headlights. They have a strip or shroud on the bulb to prevent the dazzle.
Sorry Steve - I must be able to type faster than you... :rofl:
The problem with the Civic xenon's is because they aren't through projectors they look like those tacky 'xenon look' bulbs from Halfords!
I didn't think MOT centres we allowed to adjust anything. (Certainly for the MOT anyway)
Besides, there's still only so much adjustment you could do to compensate for the different point-of-origin of the light source if fitting DxR and DxS into a halogen unit. Certainly if you're using a single reflector (e.g Felicia), you'd end up putting the main-beam into a useless position.
Well they did it before the mot, just altered it using the machine used to check the alignment . Mine are projectors though
Yeah, I've been talking about reflectors....... :doh: :doh:
:blush: Sorry concentrating too much about your latter part of post :notme:
Just to throw another few into the mix, S2000's and the old shape Accord Type R's also have reflector housings with OEM Xenon bulbs.
You can indeed, I got a set for my BMW with reflector specific bulbs which were supposed to be anti-dazzle. I paid a hefty premium for them too.
Load of tosh. Got flashed numerous times by other drivers, even after adjusting them so far down that I could hardly see where I was going, and the beam pattern was awful.
Morale of the story, if you have refelctor housings, don't even think about a HID kit, it won't be worth it.
Bulbs H7 normal, bulbs H7R with antideflector
I think H11 also has this type of bulb
The bulb itself has some type of paint so the pattern of the beam is limited so it won´t scatter all over the place.
Edited by alberg
Yes, that's the theory anyway.
As I said above though, the reality is that it still scatters and the beam pattern is terrible. :(
I'm getting really grumpy in my old age; I got out of the car at a set of lights the other week and told the little pratt in the fiesta behind me that he was blinding all and sundry, including me with his cheap s*ite ebay HIDs in his reflector lights. He had no idea what I was on about. No wonder the DOT are clamping down on aftermarket kits when idiots like that are fitting them.
rant over :-)
rant over :-)
:thumbup: :thumbup: :thumbup::rofl: :rofl: :rofl:
