Mods - what order?
The only mod I have at the moment on my 2010 FL tsi is a Shark stage 1 remap. I was all set to get a new exhaust and air intake and go to stage 2 but I'm having second thoughts. Are the gains over stage 1 really worth the cost (£1200ish) and will I be forking out for a new clutch before long?
I'm now starting to think that I should just fit the air intake that I have already bought in preparation for stage 2 and think about handling instead - Wietec springs and shocks would be around £600.
Choices, choices! What do members think: stage 2 or handling improvements?
If it doesnt stop half as well as it goes you need to buy a Mk1 Fabia VRS :giggle:
I would have thought for anything above stage 1 brakes would be an important one to look at early on I could be wrong though stage 1 has always been enough for me in my chestnut burner!
If you go stage 2 you will need a clutch. Mine started slipping immediately in 5th and 6th. It's a big improvement over stage 1, but I would recommend sorting the handling first.
Are you only talking uprated clutch on a stage 2 Tsi as this is more like stage 2+ in the Tfsi? I hope so as mine gets stage on 23rd! :doh:
Sort the handling out.
yep handling first.
front and rear anti roll bars, anti lift kit, coilovers or springs and dampers,...and thats just the start of it lol
Yeah, I think you'll be ok until you go 2+
Honestly Stage 1 plus full intake is very nice, and stage 2 is only marginally better, if you are on a budget, Suspension, brakes and a stage 1 map and intake will see you with a completely transformed car, remember you can always go stage 2 later. I wouldnt even consider stage 2 on stock suspension!
I'd say Brakes next, please remember
Speed is desirable, Stopping is essential!
After that, I'd say clutch, then possibly suspension.
Edited by Jim H
Suspension - brakes are fine for road use. If you run out of brakes on the road you're driving wrong IMHO
If fade is an issue pads - performance friction road ones or similar
Stage 2 booked in for the 23rd...... :'(
Not going to happen, so all good! :thumbup:
