RNS510 Firmware query
No
1Z0 can go to modified 2764
3Z0 & 3T0 can go to 3984.
I don't know of anyone running 4024 on any Skoda device yet. There may be some new systems coming through now but I have yet to see one on a Skoda. I've only seen D Revisions on VW
Hi, regarding the above post, I have the 1Z0 running the 1004 firmware and am wondering is meant by "modified" 2764. I read the earlier post which suggested this is needed for 7 digit postcode searching.
Adam
  • Replies 144
  • Views 45.4k
  • The way the firmware work are (they are in order of release ignore the no's as a higher no. doesn't necessarily mean a newer firmware) 1004 - Original Firmware 1024 0904 - From here down is A &a
  • Skoda has more than one revision D equivalent: 1Z0 035 680 A - hardware C3/C4A which is called revision A. Latest official firmware is 1024, unofficial - 2684, modified - 3814 3T0 035 680 - hardware
  • Yes they do work. I got a cheaper deal with vw on updating mine than Skoda offered me!!
Hi, I'm not sure which version my columbus is on, but I'll check the user manual tomorrow.
But when I press setup, the firmware version does not appear, I only see AM/FM.
My question is, do I need to upgrade the firmware progressively i.e ver 1xxxx to 2xxxx?
Can I skip the versions inbetween i.e from ver 1xxx to 3xxx or 4xxxx?
Edited by traveller78
Are you holding the Setup button down for at elast 30 seconds?
You can skip versions as long as you jump to one that still supports your particular model. If you skip from a 2xxx FW to a 3xxx fw it repartitions your hard drive so you will need to reinstall maps or music,
Yes I did, more than 30sec. Only the FM and AM radio buttons appeared. Can't see the firmware version.
I read somewhere that I need to load an additional firmware to unlock this "setup" function
At least that means that your current firmware version is below 3xxx, otherwise the "Version" menu must be displayed along with AM/FM.
You can update straight to 4020, no intermediate updates are required.
Would this work if it were an A unit though?
Thanks guys. Btw will the startup Skoda wallpaper and the "car picture" when engaged in the reverse gear, be overwritten after the upgrading of the firmware?
I have just upgraded to SW4020, I read that the sw3010 implemented the 3 partition HDD but the 4020 did not so you would not have the POI's installed so I first installed SW3010 ( which wipes maps) then 4020 followed by V8 maps with Speed cams, this is all on a 3TO 035 680 A unit and all works like a dream, much smoother graphics and quicker startup along with several new options in menus. The unit now reports back as HW05 and SW 4024 with the speed cams under the POI menu as well, been for a drive and the speed cam DB is accurate as well
  • 3 months later...
My Superb was built in June 2012.and supplied to me by my dealer less than two weeks ago.
The Columbus shows in the menu as 3T0 035 680E.
Harware version is H64
Software is 4024
Map version is 7690
Am I right in thinking that I should have had version 8 maps installed by the dealer?
Also, I'm a bit conffused by the references to the 'secret menu'...if I can read the above after holding the setup button for 5 seconds am I seeing the 'secret menu' or is there another one that can be activated? (Nothing else happens if I hold the button for 30 seconds or more).
Jim
Version 7690 is version 8. Don't ask me why the four digit number doesn't start with an 8 as I don't know, but on mine when I went from version 7 to version 8 the four digit number changed from 7333 to 7690!
However, that firmware you are on, which is what I am on, should allow you to access the secret menu, as it does on mine. You may still need to activate the secret menu with VCDS I suspect.
Adam
Thanks Adam.
Mine's going in for some coding tomorrow and I was getting ready to some desk thumpimg over the map version....that's saved me a red face!
I'll ask them to check that the 'secret menu' is enabled.
Jim
Edited by Claymore
No prob
Ok so fitted my Columbus this weekend. I have been into the secret menu and this is all I get in the Version screen.
Delivery Part Number : 3T0035680B
HW-Version : H41
SW-Version 3974
Active Map Coverage : West Europe
Active Map Supplier : Navteq
Map Version HDD : 7690.
So given that what version do I have and what are my firmware limitations ?
Thanks.
Paul
You have v8 maps (7690 is v8) which I think are still the latest, and a very recent firmware, so none really.
Thanks.
Hi, my name is Mick :sweat: and I've been sent here to see if somone can help me. I have the same problem as most on here. Please bear with me as not only am I new to forums but also a bit short on the tech side of this, but with luck I will undestand if in idiot language. I took delivery of my 2009 Superb Elegance 2ltr Tdi (Great Car) I went to use the Sat Nav, entering postcode, would only accept 5 digits, I went back to the dealer who told me the maps needed upgrading to V7.2 needles to say it didn't work. He told me the unit would need changing (£1800.00) as there was no software upgrade. B******S was my reply Having read the above posts I see it can be done. I have tried to find what version I have via the hidden menue, holding setup button for 30secs+ nothing happens except am.fm.DAB. Then I read there is something called a VCDS which I have'nt got a clue what t is or how to get hold of it, or do I already have it? All I really want to do is be able to enter 7 digit postcodes and latest version maps. Can anybody help me please. :wall:
If you can't access the hidden menu then you'll need to find a Briskodian near you who have VCDS. There is a 'sticky thread' near the top of the relevant forum which lists members and area. There is also a link to a map of the country with members locations on.
They will be able to see what SW (software) version you are on and also enable the hidden menu permanently.
V7.2 maps DO support 7-digit postcodes, it is most likely the software that is not allowing it to work.
Problem is that any attempt to upgrade the SW will probably invalidate any warranty and will probably wipe your music and map data.
Look at the My GTI website for details of each firmware (SW) upgrade and what you get.
Get the dealer to upgrade the firmware first (4xxx is the latest) then the maps (8.1) and you should have no problems then.
Thanks for that,I have just had contact from a local Briskodian who has all the neccesary discs including vcds,so looks like my problems will be resolved we're getting together in a couple of weeks.
Can't be bad solved within a few hours of post, thanks to the forum
Right, what I thought was the Test Menu wasn't, so as I had VCDS on the car yesterday I enabled the hidden test menu.
Looks like I have a Version C LED as the test menu reports :
HW Vehicle 0xC801
HW Radio 0006
So from that I guess I should be fine to apply 4024 as long as I am aware that I will need to reload the maps and any POI.
Paul
HW Vehicle 0xC801
HW Radio 0006
Yes, exactly.
Ok 4024 is currently loading on my Columbus, fingers toes etc crossed.
Failed at 14% into the APPL update - time to burn a new copy to try.
How long did you leave it at 14%?
Quite a few people have reported the same issue but I suspect they just didn't leave it long enough.
Mine paused there for quite a while (at least 10 mins), but I left it to get on at it did run through to a successful instal.
Tried three different CDs now - gives a SWL error so not sure where to go from here. Just did a Setup-Eject-Mic restart and powered it off for now. Hopefully it wont drain my battery overnight. I'm using ImgBurn and decent blank CDR (tried 2 TDK and one DataSafe)
Paul
