The definitive Yeti roof bar poll!
The Yeti roof bar question 106 members have voted
  1. 1. What Yeti roof bar would you recommend from experience?
    • Skoda original Bars (LAS630001)
      54%
    • Thule pro rack (775 footpack and bars)
      30%
    • Other
      15%
Please sign in or register to vote in this poll.
Can I ask another quickie... where supplied, do people use the 20mm x 20mm T-Track adapters or do you use one of the larger alternatives available? i.e. the 30mm x 24mm ones?
Thanks again!
  • Replies 158
  • Views 85.5k
  • I recently fitted some Thule RT 9583 roof bars, and as I have not seen these yet on the forum, I thought I'd post some pics.  They were a little more fiddly to fit than I expected, mainly as I was wor
  • I don't know if others do the same or cut the strip into three so the outer lengths can fit back in either side of the bolts - or remove it altogether. I though just popping the bolts through the hole
  • I can now join the poll as I bought the Skoda roof bars A few pics Only 8 silver studs http://s9.postimg.or...1b/P1010001.jpg 3mm Allen key. Not Torx http://s1.postimg.or...5b/P1010002.jpg
Thanks again!
Since you've just bought the Škoda system you can obviously only fit things into that groove that is as wide as that. I don't have mine to hand to measure so not sure if the 30mm ones fit or not.
The ones The Roofbox Co offer for the Skoda bars are 20mm square and are a reasonably close fit. Can't measure the bars at the minute but at a guess I'd say anything much bigger (width across the groove) wouldn't fit and longer along the groove won't, in reality, add anything secure-wise, if that's a concern. The 20mm sq are a secure fit.
  • 6 months later...
  • 4 weeks later...
Just as a follow up, I bought the above bars, they fit & work great, take about 20 mins to fit the first time, after that about 5 mins, (paid £61.00 for them delivered using an online 5% discount code). I have just ordered a Thule Motion 200 to fit onto them for our camping trips.
  • 6 months later...
Apologies for dragging this thread up again, but I guess it's good to add to the old thread than start a new one.
I'm looking for some bars for a new Yeti and I'm drawn to the Thule Wingbars Edge 9583. Apart from the extortionate cost, are there any downsides with these bars? I like the idea of fitting them further apart than the official Skoda bars and their lower profile (I don't have a sunroof). Is there anything to be gained from the WingBar 969 with 775 feet over the Edge model?
How easy are the Edge to put on and take off?
I picked up some 2nd hand Pro-rack aero-bars S45.
Totally quiet and negligible effect on MPG.
Lowest profile.
Because they clamp on you can position where you like.
The Thule Wingbars were not compatible with my FL Yeti with sunroof and Thule roofbox attached. The glass roof would hit the clamps... I didn't go for the 775 because of the width and so I ended up getting the Skoda roof bars. And I'm satisfied.
Bought the Genuine Yeti roof bars and slightly regret it... they do look smart on the car however they aren't as accommodating as the Thule ones that allow you to set them further apart than the designated Yeti roof bar attachment points.
