Knocking when braking and setting off
Hi guys.
Noticed this today and bit worried
When I brake and just about to stop I hear a knocking sound coming from under the car at front the sound is also there on occasional setting off.
Now on Thursday I had new top mounts, weitec new , oem drop links, new front wishbone front bushes and new powerflex arb bushes fitted.
Console bushed were done last year and has cupra ones fitted.
What the hell can the knock be lol?
Upon searching on here it seems the arb bushes are the main reason for knocking
Anyway to check mine were fitted correctly? Is it a DIY job to take out and put back in? (just to ensure its in place ok)
Could it be anything else?
Many thanks in advance.
Thanks.
  • Replies 78
  • Views 6k
  • Thanks mate Luckily I bought some mondeo mk1 drop links when I bought all the kit for the coilovers. Anyone know the correct procedure to change he drop links ? Ie take both wheels off do I need to
  • Knocking noised cured
It will be the coils on the coilovers touching mate.
ahh
just been under the car and the ARB is rock solid, no play in drop links either
is the coils touching something i have to live with or is there a fix mate?
thanks
Is it coming from your drivers side?
It sounds like it yes.
I've just done some more Searching and others have mentioned driveshaft hitting the arb? I take it I can't see this if the car is jacked up ?
Same prob as me I have had my AP coilovers on for about a year and now all of a sudden my drive shaft is hitting my arb people are suggesting shorter droplinks m8
What coilovers you running and are you using standard droplinks
You'd notice scoring on the driveshaft dude
Thanks guys
Using weitec gt hicon and using standard size drop links as thats what I read I needed to use as the weitec/ap/kw don't need shorter ones.
Il check under the car tomorrow.
As I said its just when I brake and come up a stop all the engine weight going to front of car and putting pressure on the coilovers.
Kind of wished I bought adjustable drop links now lol.
Awesome gti do some shorter droplinks for £30 don't know if there any good tho
Thanks mate
Just a quick question about them, how do I know what length to adjust them too?
I guess is just 2 bolts to take out the drop link, should be easy enough!
I've just ordered some m8 so I'm not to sure but I was told when getting my AP's I would be fine with my standard ones but not anymore so this will pull the arb away from the shaft well so it says on the sitr
Thanks mate
Anyone know the correct procedure to change he drop links ? Ie take both wheels off do I need to jack the hub up aswell?
What mondeo ones did you get?
Where from?
Part no.?
So mk1 mondeo ones are they much shorter than the standard
took this pic last week
top is mondeo from that link above and bottom is meyle HD standard
They look OK, if I knew which ones I would of headed into TMS
It's not the drop links dude. Seriously don't go wasting your time when short links are fitted with weitec they knock like hell. The noise is the coils rubbin on each other. Weitec gave customers a free length of rubber tubing that was slid onto the top three ish coils to dampen the sound.
It's something mine don't suffer from but mine were second hand so I guess they were broke in as such. Others put up with it and others fit that tubing but I can only see that been a temp fix as the rubbery plastic tube would surely rub through. I've got some of the tubing if you want me post a pic etc?
Have asked dpm up get me some sleeving
I think your right noise sounds like coil clanging each other.
Mondeo droplinks getting fitted tomorrow morning, it doesn't sound like the springs and my mechanic told me my drive shaft has been hitting my arb.
What does this tubing look like?
Let us know how it goes mate.
Will do m8 fitting them early morning and he says it will only take 15 mins to fit
