Knocking when braking and setting off
Like i say this is second hand info about the foc thing, im sure damien wouldnt over charge you dude.
  • Replies 78
  • Views 6k
  • Thanks mate Luckily I bought some mondeo mk1 drop links when I bought all the kit for the coilovers. Anyone know the correct procedure to change he drop links ? Ie take both wheels off do I need to
  • Knocking noised cured
I'm contacting KW tomorrow or venom to see if I can get it for the price of on the house :)
Think over the weekend I'm going to replace mondeo links with new standard ones and strip my coilovers and re grease and new bump stops and top mounts.
What bump stops:
Top mounts:
Will I need thanks
bump stops on the rear i went with ibiza fr ones or you can shop your standard ones down.
top mounts i had genuine from tps including bearings
oem drop links and top mounts can be found on vwspares.co.uk or TPS as hux says
FR bump stops from TPS work a treat!
Noob question tps?
Never heard of them are they like TMS.
Does anyone replace the front bump stops?
Edited by andyvrs12
Noob question tps?
They come built into the coilovers mate.
so they cant be replaced then? But i can do the rears
Not sure if they can be replaced , maybe huxley will know.
Back ones definitely can be replaced. I did mine last week.
If only the front were as easy to get off lol (for me anyway!)
No need replace them if they come with the coilies. rear coilovers dont come supplied with bump stops so you use yours and cut it down or get shorter ones like me and biggy
Thinking about it guys if you jack your front end up so there is no pressure on the coilover and then fully wind the adjuster down I think the spring will be slack enuf for you to put this sleeve on.
Good thinking there ;)
Thanks for all this useful info lads!
I never cut down my originals ones down on the rear when I fitted my coilovers :( whoops
i mailed Weitec today about the coil slap
their reply
Hello,
please double check with your workshop the enclosed installation manual (especially page 5!). We suppose the problem comes from a wrong installation on the front axle.
Mit freundlichen Grüßen / Best regards
KW automotive GmbH
anyone around Manchester spare an hour to have a proper look for me? lol
ea_13282022.pdf
Wrong installation: 0
cant see that it is tbh, they do coilovers day in day out
will have to take it back or to another local garage to check
Passing the buck phrase right there!
Has your hose arrived? If i were you id fit that first before you go paying for more labour.
PS you cant really install a coilover wrong. Its fairly simple.
Thats what im thinking is it even possible to fit them incorrect :bandit:
il try the sleeve then.
so take wheel off, loosen the front adjuster (twist to bottom) so coils are at full stretch and see if i can pull the sleeve on the coil?
just to confirm hux is it defo the top 2 coils i need to cover or bottom 2?
Its the top coils mate and yeah take weight off and wind the adjust all the way down.
Nice one mate.
been doing loads of reading on other forums about coilover creaking - some posts suggest console bushes/ARB bushes
as quick fix/diagnoses i plan to grease the ARB bushes, console bushes then finally the top of the coilovers
doing this day by day to see if the noise finally goes, have ordered some spray grease.
i know im beating around the bush but i jut don't have the time to do the sleeves over the coilovers at the moment, hopefully weekend
right
had both front wheels off today, loosened the coilover down as much as it went but still the coils were too tight for me to slip the sleeve over it.
i bought some spray grease and greased up the ARB bush, console bush, front wishbone front bush and top 2 coils towards the top mount which i thought cured the creaking on test drive, then it came back lol
im thinking i need some kind of coil compression tool so it allows me to put the sleeve over the coil at the top yes?
these ones: http://www.ebay.co.uk/itm/2-PCE-COIL-SPRING-COMPRESSOR-CLAMPS-CAR-HEAVY-DUTY-31cm-LENGTH-/160736960587?pt=UK_Hand_Tools_Equipment&hash=item256cab604b
thanks guys
have ordered some compressors from amazon, should get them tomorrow
will see how it goes over the weekend
