VCDS question
Hello everybody,
I googled XDS settings via VCDS and I only saw address 36. I have VCDS 11.11.2 version and when I check the address it seems like "Seat Mem. Drv". Can you please help me about the solution? I can not enter to XDS settings.
There is a screenshot here,
Hi,
In VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
Channel 36 XDS
There are 3 settings
0-center (stock setting)
1-weak
2-strong
Hope this helps,
Tim
Hello Tim,
Before I read your post, I found it as you wrote down. I really thank you.
I have another question ,
Channel 09 Brake Assist is there but it says "Security Access Required" I had my VCDS from China tbh. and I'm not sure what is the security address code. Can you help me about it?
